Windows 10 shutdown shortcut
- Has thanked: 105 times
- Been thanked: 880 times
Ye olde shutdown shortcut still works on windows 10
1. Right click on the desktop
2. New - Shortcut
3. A window will now pop up in the box type the following - shutdown.exe -s -t 00 - press the next button
4. give it a name
5. your done
If you want to change the icon right click on the shortcut you just made - properties the click on change icon - it may pop with a error just click yes - select the icon of your choosing or make your own
2. New - Shortcut
4. give it a name
5. your done
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Re: Windows 10 shutdown shortcut
Only way to shut mine down at the moment is to press and hold the power button on the tower. Otherwise it justs comes back to life after a minute or so. the same with sleep mode.
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Scruff, some simple things to try......thescruff wrote:Only way to shut mine down at the moment is to press and hold the power button on the tower. Otherwise it justs comes back to life after a minute or so. the same with sleep mode.
Unplug all external things (USB devices mainly) and try and shut down.
If using wired network, unplug and try to shut down
Some motherboards allow 'wake on events', which is why it's good to rule those out.
Still reckon it's a BIOS setting. What PC/Motherboard do you have - is this the Aria PC?
BG
- thescruff
- BillyGoat
- Troll Headbutter
Do you know what BIOS version you are on? (press Windows key and R to bring up the run box and type msinfo32 and click the .exe version - it's on the first page).thescruff wrote:Gigabytes P67 X-UD3-B3
BG
- thescruff
Bios version Award Software International F4, 4/13/2011
OS Name Microsoft Windows 10 Pro
Version 10.0.10240 Build 10240
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name USER-PC
System Manufacturer Gigabyte Technology Co., Ltd.
System Model P67X-UD3-B3
System Type x64-based PC
System SKU
Processor Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz, 3701 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Award Software International, Inc. F4, 4/13/2011
SMBIOS Version 2.4
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.10240.16392"
User Name User-PC\User
Time Zone GMT Daylight Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.98 GB
Available Physical Memory 5.70 GB
Total Virtual Memory 8.48 GB
Available Virtual Memory 5.23 GB
Page File Space 512 MB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
System Name USER-PC
System SKU
SMBIOS Version 2.4
BIOS Mode Legacy
- BillyGoat
- Troll Headbutter
Hmm, F4 BIOS revision was released on the 14/April/2011 and it's up to release U1B (for F10b stable). While they are scant on detail, things like UEFI support are a bit of a giveaway that they are geared up towards W8 (and W10, by extension).
Would be top of the list of things I'd do myself, but I know not everyone is keen. I'd imagine your board has BIOS backup if sh*t hits the fan (but check).
Also, check BIOS settings if you do it and you have RAID in action - don't blame me if it looses your RAID set after!
Have you tried to remove accessories and shut down first? Simple and free.
BG
BG
- thescruff
- thescruff
Ran BiosAgent plus and 0 device drivers are available for this machine. However it points to an Award update for xx $.
Gigabyte are very good with getting updates for bios issues out, Nearly every build I have done in the last 15-20 years has been a gigabyte motherboard
http://www.gigabyte.com/products/produc ... =3815#bios
it just come to me on another thread look in control panel (win + x) - power settings and see what the power button is set to do
- thescruff
Em think I'll leave well alone.
UEFI BIOS
(When updating from legacy to UEFI, use only the utility attached to your BIOS file)
(Note) Some GIGABYTE utilities are not supported under UEFI BIOS architecture. Please remove Smart6, Dynamic Energy Saver, Smart TPM, and Touch BIOS utilities before updating the BIOS.
UEFI BIOS
- thescruff
Yes Tiger it has a shutdown and re-start.TigerUK wrote:whats the problem? doesn't windows 10 have a shutdown feature?
The problem is it doesn't turn the tower off and a few minutes after shut down it comes back to life, even got a shut down button on the keyboard which does the same thing now.
Holding the power button down on the tower turns it off so no big problem more annoying.
- BillyGoat
- Troll Headbutter
I'd imagine the utilities are not supported and not even needed. Do you use them? I've not got a single one of the manufacturer utilities installed on mine (and there are LOADS).thescruff wrote:Em think I'll leave well alone.![]()
UEFI BIOS
All of the power management is fully functional, the USB charging, etc, etc, etc.
Up to you though, of course.
BG
