Forward planning~ NO!
Posted: Sun Mar 02, 2008 10:36 pm
by Mooncat
Son bought an air ratchet drive for use with his compressor. The quick-release adapter is supplied by them, but see what happens when you install it. Someone wasn't planning ahead!
I have a 9" anglegrinder, but it won't fit into its well-made case, unless you remove the disk and guard first.
Is it usual for this sort of thing to happen?
Posted: Mon Mar 03, 2008 4:27 pm
by chippymike
must be one of the cheaper brands that can't get everything right
Posted: Mon Mar 03, 2008 6:36 pm
by Hitch
A lot of them cheappy cases are like that. Just take a round file or rasp and notch the case to suit
Posted: Mon Mar 03, 2008 7:03 pm
by Mooncat
Hitch wrote:A lot of them cheappy cases are like that. Just take a round file or rasp and notch the case to suit
Will have to do that, but lose the dirt excluding idea of keeping it in a case. He'll have to keep a cover for the end of the coupling. I can understand economising on components to keep the price down, but surely it doesn't cost much more to make tha case bigger?
Posted: Mon Mar 03, 2008 8:55 pm
by Hoovie
pretty standard thing, sadly.
the Bosch PMF180E case only closes when one specific blade is attached to the tool - any other blade and you're screwed
Posted: Mon Mar 03, 2008 9:07 pm
by Hitch
I wouldnt worry tbh. Ive never had a problem with any of my air tools, ind i will guarantee they are stored in a far dirtier enviroment than his will be
