shed
handyman
Has thanked: 6 times
Been thanked: 11 times
shed
Post by handyman »
I'm thinking of making a shed 18' x 6' with the height being 7' one side and 6' the other (ie, with a sloping roof) Finally getting the bomb shelter/outhouse removed from my back garden.
Just cant buy a shed this dimension, and ones that are close to it, are made from very thin wood for the money.
I'm thinking of making the walls from 6" t&g floor boards. Local sawmill are doing this for £1.50 per m.
Is this ok as shed walls? Anything better, cheaper, more appropriate? And is the price OK.......it works out 20% cheaper than bnq. I try not to go to howdens(have trade card), but will they do this wood cheaper?
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
I think it's OK as long as you treat it both sides, gives you more options on how to insulate etc.
I'd love to have a shed that size.
John
chippymike
Has thanked: 16 times
Been thanked: 9 times
Post by chippymike »
long as you treat it with cupronol *sp it will be fine
handyman
Post by handyman »
i have a 'source' for super dooper solvent preservative :wink:
Would it be better to have a small (1mm?) gap between the planks, or have then butted up to each other?
Has thanked: 736 times
Been thanked: 2341 times
tends to be cheaper to use 5" txg shiplap as its around £1 a mtr as 6" is proportionaly expensive
you need the wood to be thoroughly dry and butt up tight as i found to my expence
i will try and find the my shed thread :scratch: :scratch:
so i can point out the pitfalls :scratch:
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
Jaeger.
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
Personally i'd go with big-all's suggestion Handy. :thumbright:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
handyman
Post by handyman »
will ask about the 5" txg shiplap
cheers :thumbright:
handyman
Post by handyman »
5" shiplap (loads of it) sitting on the drive..........if it stays dry on monday, will put it together into panels, tuesday, complete the base and assemble the panels..........with any luck, completed tuesday evening
but probably not :sad:
got it from bnq for £1.10 a metre (including vat and delivery)........they sub it out to a saw mill who delivered it from bolton :shock:
it was a negotiated price as usual. Bloody good deal :thumbright: and you get 5% cashback every quarter
assuming its txg!!!
if its wet do not assemble till dry the coverage of a plank should be 110mm max any more when dry your planks will seperate :cb
handyman
Post by handyman »
txg ??? Is that tongue and groove? If so, then it is.
what do you mean 'the coverage of a plank should be 110mm max' ?
The planks are 125mm x 19mmImage Looks like this
handyman
Post by handyman »
the coverage is what a plank will cover when connected to another
in otherwords from the shoulder to the side off the tounge to the bottom of the board :thumbright:
handyman
Post by handyman »
its 110mm :-)
ok ram it home tight dont leave any gaps and in the summer it will open up but no too much
i personaly would screw each plank in work up from the bottom to shoulder height and if the roof is on from the roof down and adapt a bit in the join with a router to fit in the gap
have you seen my boring long winded thread about my shed tat was several pages long!!
