Clarke lathe modification.
Retired
Has thanked: 2019 times
Been thanked: 588 times
Post by Retired »
At last I'm starting to do jobs I want to do rather than jobs I have to do. A few years ago Bron kindly bought me a Clarke CL300M metal turning lathe as a Christmas prezzie. I had sold my big Colchester so wanted a small lathe until I bought another lathe to replace the Colchester which was too big for the garage it taking up a big footprint.
I'm used to big machinery so first job was to destroy the circuit board and motor on this Clarke both expiring in a cloud of smoke much to my dismay. I had been putting a light cut of 60 thou on when it expired having not read the manual. Now when I read the manual it states do not exceed 10 thou cuts? 60 thou to me whilst using the big Colchester was merely scratching metal and I thought I'd have no trouble with such a small cut on the Clarke but it was an expensive lesson to learn.
No way was I going to spend over £100 for a flimsy circuit board and I hadn't a clue what the tiny motor would cost and couldn't care less if this was the performance to expect? To cut a long story short I bought a brand new industrial sewing machine servo motor which too was variable speed. I grafted this much larger motor on but had to do this by designing and installing a countershaft into the original tiny motor housing; it was a squeeze but I did it.
The servo motor is lever operated for start/stopping the lever returning to off by a powerful spring so obviously some kind of linkage would be needed but at the time I was bogged down with more pressing jobs so came up with a very high tech solution by cutting a block of wood just long enough to wedge between lever and chip guard and I got very used to popping this block of wood in but it always bugged me. Having finally caught up I've been giving this problem a lot of thought and it proved a lot more difficult to resolve than ever I expected in fact I had a couple of attempts without success.
This morning I wandered into the garage after pulling the car out to give the car another soaking and really set about this problem. I measured the end of the motor lever at the hole and found the travel from Off to On to be just 1". Sorting through my stock of metal offcuts I pulled out an assortment and I also found a knob on a bent lever which looked like it could be useful? Bits of angle iron and metal strip were measured and cut; from the bracket I installed the distance to full on was 4" so I cut metal to suit this drilling three fulcrum holes the lengths of metal being hinged in the middle. 1/4" holes were drilled throughout allowing both 6mm set screws and nuts plus three short lengths of 1/4" dia silver steel for the fulcrum pins these pins being drilled across axis near each end to accept a common split pins to retain them in position.
The pictures show better than text the design of the linkage which I put together; not very pretty but it works perfectly. The two halves of the linkage form an hinge and in the off position the hinge is a steep "V" but at the on position the hinge travels just past horizontal and is arrested by a flat piece of steel locking the motor on until the knob is actuated to release it.
At last the Clarke is now fully working as it should; the servo motor cost £160 plus the cost of countershaft bearings and drive belt etc but for around £200 and plenty of head scratching the Clarke is now a much superior and robust lathe than when new. I appreciate in order to sell such lathes for hobby use they are built down to a price but the circuit boards and motors supplied as original are just rubbish; I'm sure Clarke will do a roaring trade on these two items but not for me thank you I dislike expensive junk.
Since the servo motor has been installed I've used the Clarke a lot and now it's a nice little lathe capable of a decent cut which I hand feed; I dare not engage power feed with a decent cut applied due to the plastic gearing which I don't wish to strip but so far this Clark is a nice small accurate lathe although I certainly would never recommend anyone to buy one because the circuit board and motor are much too flimsy. I've enjoyed today and what a pleasure it is now to work in bright daylight in the garage under the new LED panel lights whilst it remains the usual black hole outside?
A couple of days ago I decided to upgrade the terrible tail-stock clamp; this flat metal plate clamp was rubbish it allowing the tail-stock to wobble all over the place so I increased thickness and length which has now made sliding the tail-stock more of a pleasure.
Next job is to have a go at installing a new Balata flat drive belt onto the bigger Lorch Schmidt lathe.
Hope this is of interest?
Kind regards, Col.
Block of wood..JPG (177.17 KiB) Viewed 9437 times
Servo motor..JPG (173.11 KiB) Viewed 9437 times
Off position..JPG (184.14 KiB) Viewed 9437 times
On position..JPG (179.24 KiB) Viewed 9437 times
Past horizontal..JPG (138.35 KiB) Viewed 9437 times
From front..JPG (175.76 KiB) Viewed 9437 times
New clamp..JPG (151.94 KiB) Viewed 9437 times
These users thanked the author Retired for the post (total 2):
Dave54Mark Hello (Wed Jul 15, 2020 4:09 pm)
Rating: 14.29%
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Re: Clarke lathe modification.
Post by Dave54 »
Thanks Col. There was one of these for sale locally to me "As new and unused" still boxed. It was about half newprice and I was tempted, but decided not to as the ancient, although fairly knacked Drummond round bed I have does the occasional odd bit I need.
Anyway I'm glad I didn't bother now, I can see that motor having lasted about the same time in seconds as the maximum cut in thou'.
And plastic gears. Umm. . . :shock:
ETA Nice job on the motor conversion. :thumbleft:
These users thanked the author Dave54 for the post:
Retired
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
It's inspiring (as always) to know that cheap'n'cheerful equipment can be made into something much more capable under the hands of someone with a bit of knowledge and experience.
Such modifications should be made into Youtube videos Col - I reckon you could get quite a following and there's money to be made for popular Youtubers (I know money won't interest you but putting your ideas 'out there' would certainly benefit many other hobbyists and preserve the knowledge - legacy and all that :lol: - not that I'm hurrying you on :lol: :lol: ).
Great stuff.
These users thanked the author kellys_eye for the post:
Retired
Retired
Post by Retired »
Thanks Dave54. You did the right thing in not buying the Clarke even if it was new and a bargain price. These small Clarke lathes would be so much better if Clarke did away with the electronics and installed simple 4 speed stepped pulley belt drive and changed the plastic bits to metal then it would be a nice little lathe which would attract favourable reviews. As the Clarke is currently supplied with full electronic speed control using a flimsy circuit board and equally flimsy motor then I'm not surprised it's receiving such bad reviews; pity I didn't read these before Bron kindly bought me the Clarke. For the price of a brand new Clarke I received little more through eBay for my wonderful industrial Colchester Triumph with lots and lots of tooling; if I had plenty of space I'd have never parted with my big machines but I became fed up of bumping into them in the garage. Plastic gears on a lathe I think the Lathe should be called Lego?
Many thanks k_e for your kind comments. Unfortunately these days I'm a dinosaur of a time when apprentices were taught hands on the only classrooms being one day and two nights a week at tech paid by the National Coal Board. I was taught on the old style machines where the machine operators skill was required to produce accurate components; electronics were years away in fact only a few years previously our cottage had been changed to electric lighting from gas so I'm indeed one of the originals? As you rightly say k_e I'm not into my hobbies to make money but I might have a go at trying to create a video to add to YouTube but at the moment I haven't a clue as to how to do this but I'm a quick learner. I avoid electronics as much as possible when it comes to buying big kit; modern machinists are actually mostly programmers? The machines I like are the ones where I need to use my head and hands turning handles etc rather than pushing buttons. For one off jobs I'm sure I could have the job done manually by the time a CNC machine was tooled and set up; CNC machines are the business for production runs and do a superb job. I would consider adding DRO (digital read out) though to save taking vernier/micrometer readings?
These small Clarke lathes attract good money on eBay but I wonder how many end up with blown circuit boards/motors? :cb
Talking of lathes I need to install the new drive belt onto my big Lorch Schmidt lathe then I'm well covered for turning metal with the Clarke and Lorch and for turning wood with the Record DML24" and the Union Graduate. You can't have too many lathes. :thumbleft:
Kind regards, Col.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
these lathes are rebranded SIEG lathes there is loads of info on the net about modifying these
parts are available through http://www.arceurotrade.co.uk/ and they do a few upgrades for them and do the SIEG machines in red
I have the small SIEG C1 lathe (axminster tools branded and white) I also have the Clarke mini Mill again its a SIEG X1 Mill not bad little machines for the money but you do need to strip them right down when new to get the tolerances down to something usable, the c1 is gutless if turning anything harder then mild steel
These users thanked the author Bob225 for the post:
Retired
Mark Hello
Has thanked: 2 times
Post by Mark Hello »
Hi Retired, thank you for your info on changing the Clarke CL300 M lathe, we have recently bought one for my son Sam who wants to be a engineer and be like but better than Guy Martin one day haha.
The lathe we bought he has broken three times now the last time we think it is the mother board, from reading your info it would seem the logical step to take and copy what you have done.
I have a question which may seem thick so bear with me. Your lathe will only rotate one way ? Being all knew to this dose it make a big difference if it is only one way or not in the long run, plus have you any recent updates on your lathe?
Thank you for your time all the best.. God help me he has bust my G clamp now.....
Has thanked: 823 times
Been thanked: 3560 times
Retired does not post on here anymore but I have sent him an email and asked if he will have a look at this thread. I have no idea if the email will reach him as I am not aware of his present circumstances. He is a decent chap though who is very knowledgeable so fingers crossed :thumbright:
Mark Hello (Wed Jul 15, 2020 4:14 pm)
Mark Hello
dewaltdisney wrote: Wed Jul 15, 2020 2:52 pm Retired does not post on here anymore but I have sent him an email and asked if he will have a look at this thread. I have no idea if the email will reach him as I am not aware of his present circumstances. He is a decent chap though who is very knowledgeable so fingers crossed :thumbright:
Thank you for your post I appreciate , well I am off to you tube now to see if retired did make a film of his clarke lathe jouney, much apprecaite all your veiws thank you.. Mark
I heard back from Retired and he has asked if you care to email him he will respond. Check your Message Box on here as I have sent the contact details to you. I think you can read messages but not send any until you have done 10 posts on here. Come back if you get stuck.
moderator2 (Wed Jul 15, 2020 4:58 pm)
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Post by Chippo1 »
An old Myford seems like an attractive proposition !
Retired
Post by Retired »
Many thanks dewaltdisney for contacting me I haven't posted on here for a long time but because of the seriousness of Mark Hello's question regarding running a lathe in reverse I just have to respond on the forum. Older type or any lathe fitted with a threaded chuck to secure it to the mandrel must never ever be run in reverse with this kind of chuck installed; there is a serious risk of the chuck unscrewing becoming a heavy missile which could actually kill.
Lathes designed to be run in reverse are fitted with a taper lock mounted chuck making them safe. During my 55 years of running all kinds of lathes I've never needed to run an engineering lathe in reverse; I was taught how to screw cut in a lathe but again never had to I use taps and dies which save lots of setting a lathe up. I prefer HSS (high speed tooling) it can be easily sharpened unlike TC tipped tooling.
Good on you Mark Hello for encouraging your son Sam to use a lathe; he'll enjoy it once he grasps the basics but please drill into him the dangers posed by even a small lathe.
https://www.youtube.com/watch?v=0X1nZwOZH6M
Above is a link to a top class lathe tutorial which I highly recommend and agree with; I've been married 44 years and still don't wear a wedding ring because of the dangers involved.
I like older type lathes without complicated electronics to go wrong but I do use electronics at times as in powering both my Union Graduate woodturning lathe and Lorch Schmidt precision engineering lathe from a single VFD with switching between lathes ensuring only one lathe can be used at a time.
Please feel free to contact me Mark Hello if you think I can be of help.
Kind regards, Colin.
dewaltdisney (Wed Jul 15, 2020 7:11 pm) • moderator2 (Wed Jul 15, 2020 7:24 pm)
Rating: 14.29%
Chippo1
Post by Chippo1 »
I have had a face plate spin of my Myford ML8 wood turning lathe and dance around the workshop!
These users thanked the author Chippo1 for the post:
Retired (Thu Jul 16, 2020 8:39 am)
