Preperation required for tiling
re-dec
Post by re-dec »
Hi all,
Hope you can help and advise me as it would be much appreciated.
I will be ripping out our bathroom shortly and the tiles have been stuck directly to the honeycombed plasterboard walls. in order to be prepared all ready for tiling please could anyone advise on the following.
bath/shower area - tile backing board to be used any particular thickness? Should I tank this area or is the backing board enough and will this effect the tile adhesive sticking to the board. board joints to be covered with jointing tape?
remaining walls- standard plasterboard to be used.
Thanks for finding the time to read please point out if I have missed anything and if this is correct spec prior to tiling.
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Preperation required for tiling
Post by steviejoiner74 »
If your walls are honeycombed they are most likely to be paramount partitions and you'll need to be carefull you don't pull away the other side. They are generally only 60mm thick overall and are slid over a top and bottom runner during construction in wall sections and a 35mm stud is jammed in the honeycomb section every 1200.
Photos of the wall in question would help before advising on resheeting the wall.
re-dec
Post by re-dec »
Hi Steve,
Thanks for your reply. Unfortunately I wont be able to show any photo's as I am just researching at the moment and plan on doing this in the summer. I believe it to be honeycomb as the other walls in the house are although it is possible that it may not.
kingnewport
Has thanked: 19 times
Been thanked: 21 times
Post by kingnewport »
Best using cement board although people like myself still yluse plaster board . You can tank it its up to you really
Sent from my SM-G920F using Tapatalk
re-dec
Post by re-dec »
Hi Kingnewport
What use cement board just round bath/shower area or for whole room? Also do you know if tanking the area will effect the tile adhesive sticking to it?
kingnewport
Yer just use around wet areas . No need all over.
No the tank is fine to tile onto. Just check the manufacturers warranty on it.
Return to “Tiling Forum”
