Hinge opening
stevec59
Has thanked: 16 times
Hinge opening
Post by stevec59 »
I've just had a unit fitted from B&Q and I used the 110 degree soft close hinge as below
http://www.diy.com/departments/cooke-le ... 263_BQ.prd
My unit is next to a wall so could really do with stopping at 90 degree, but B&Q don't see 90 degree, is there any way I can stop them opening so far and bashing the wall?
Many Thanks
Steve
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Hinge opening
Post by steviejoiner74 »
Put a stay on or just be careful when you open the door.
I'm pretty sure you get 90 degree hinges from B&Q tho.
These users thanked the author steviejoiner74 for the post:
stevec59
Has thanked: 831 times
Been thanked: 3630 times
Re: Hinge opening
The only 90 degree hinge I know is the lay on type concealed hinge see http://www.manddonline.co.uk/index.php? ... ts_id=3168
Fitting a pair of these would do what you want but it would leave the door hinge mortices exposed. You can buy push in plastic covers but this might be tricky to match up your door colour.
stevec59
OnlineOnline
stevec59
Re: Hinge opening
Post by stevec59 »
steviejoiner74 wrote:Put a stay on or just be careful when you open the door.
Thanks, I can't see anything on B&Q web page but I'll email them, but they don't try too hard to answer people ::b
What do mean by a stay? And how to fit
Steve
transitboy
Has thanked: 379 times
Been thanked: 584 times
Re: Hinge opening
Post by transitboy »
Ironmongary direct do a 95deg one
These users thanked the author transitboy for the post:
stevec59
stevec59
Re: Hinge opening
Post by stevec59 »
Thanks, actually I just found some 90 degree ones on Amazon
http://www.amazon.co.uk/gp/product/B00P ... _pC_nS_ttl
I'll give them a try
Steve
Re: Hinge opening
That hinge looks more like 180 degree opening in the link picture?
OnlineOnline
speed
Has thanked: 35 times
Been thanked: 257 times
Re: Hinge opening
Post by speed »
te amazon ones you linked not designed to fit at 90degree closed so wont fit,
if you look at the data image it shows the fixing plate screwed on the back of the panel next to it
pfb5
Has thanked: 67 times
Been thanked: 106 times
Re: Hinge opening
Post by pfb5 »
The Amazon ones are for FRAMED units:
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Re: Hinge opening
Post by London mike 61 »
I know absolutely nothing about hinges as such but I happen to be browsing for something else and came across this; http://www.toolstation.com/shop/Ironmon ... ung/p13965
I don't know if it is any good for what you want but I thought I would pass it on anyway
Good luck
Mike
Re: Hinge opening
That is what I advised earlier Mike :thumbright:
OnlineOnline
London mike 61
Re: Hinge opening
dewaltdisney wrote:That is what I advised earlier Mike :thumbright:
Oops, sorry! :oops:
Re: Hinge opening
I am the worst for not reading threads and jumping to a conclusion Mike :lol:
OnlineOnline
Return to “Kitchen Fitting”
