Load bearing / Not enough mortar?
Posted: Sun Jan 10, 2016 8:58 am
Hi all -
First off, I'm new to this DIY gaff so if I use any incorrect terminology, please forgive me
My parents have recently had their bathroom refitted by some friends of friends. I got to see the fitting process partway through. The picture accompanying this post (as an example) is of a set of tiles directly above the shower-base. My queries are as followings:
1) With regards to the specific picture supplied above the shower-base (no vapour barrier included if one was needed) the mortar does not cover the entire back of the tiles. Is this normal? My worry is that if any undue pressure is added to sections of tiling that have no mortar behind them, the tiles will likely break. In the future for example we may have to fit a hand rail.
2) In part related to point one, but on a different subject. We have a bathroom cabinet to hang above the sink. The cabinet itself is very heavy. Again, I have concerns regarding the gap behind the tiles. We need to hang the cabinet but am very concerned about [A] drilling through the tiles(given the gap), and ensuring that it's actually the wall behind the tiles that is bearing the weight of the cabinet and not the tiles/mortar/plaster in between. So much so that we're thinking of getting someone in specifically to hang it, but where would we start?
Any help or advice on the above would be appreciated.
Regards -
bluebear
Regards -
bluebear
