Old style rubbish bin storage doors!
I know this sounds stupid - but i have been searching everywhere to find replacements for the old wooden gate doors on the brick bin storage unit outside victorian style houses. their about 3 or 4 ft tall. do i/expert have to make them? or is there a name for them that I am missing which will make my search for ready made ones easier? please help! thanks
Desperately needs advice!
Ledge and braced door
or
framed Ledge and braced door
And I think you will need to make them your self using 15mm thick match boarding and Ex 150 x 25 for the ledges and braces, due to them not being a standard height.
Sorry but I don’t know the standard widths the match boarding comes in, but know doubt another member can tell that.
or
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
would avoid the diy sheds like the plauge as doors need stable wood
any twist bow cup will throw the door out of square
go to a wood yard not only will the wood be better quality rather than come up as 18mm it will be 22mm and more likly fit into the frame fitted
- Wood Magnet
- Been thanked: 3 times
There may be an alternative style of gate; a slated ledge and brace gate. This type of gate as gaps between each slate thus allowing the wind to pass through it a lot easier it also allow good ventilation if used to enclose a bin store etc.
Have a look at the drawing it just may be of help if not a lot.
- big-all
- Pro Carpenter
could you please show us a picture or describe the bin storage area !!
is it coverd !!
is it secure!!
has it got a frame with around 44mm rebate in it !!!
does it have T hinges at present or other type !!
http://www.screwfix.com/prods/76908/Iro ... inge-406mm
is it coverd !!
is it secure!!
Another option for hinges would be to use Hook & band or for a more decorative finish this type of hinge could be used
And don’t forget the handle / latch
