ceramic tile over vinyl over black mastic/glue
Posted: Fri Jan 22, 2016 8:46 am
I have googled and most say it is a definite no. However American Tile Council says yes if solid substrate. Good old Google, many opinions. Hoping experienced people here will add to debate so I can decide.
300 x 300 x 6mm ceramic tiles for small kitchen floor area approx. 3x2m square.
Underneath loose vinyl sheet, removed, is thin vinyl tiles on a black mastic/glue.
These tiles are well fixed, solid. Tried removing, tops crack out with difficulty, leaving grey underpart. If that is removed by chiselling, leaves thin black glue/sealer/mastic ( don't know what) on concrete.
The black stuff is right into pores of concrete. Very hard scraping took five minutes to remove a few centimetres. Would take ages to remove and still leaves a thin skin in concrete.
I have read that a flexible adhesive, thin bed, would be fine straight over the (scarified) vinyl and preferable to over the black. Also read the black may have asbestos in so very wary of long tedious removal job if flexible adhesive would work over vinyl. It is a thin, hard vinyl.
Best adhesive? Had tilers use a blue plasticy tile adhesive once that stayed flexible to an extent after dry. Dried grey but still blue inside. Would stick anything to anything. In various places they stuck slate to chipboard, cement sheet, wood, plasterboard, metal, concrete. Not one fault in twenty years. Anyone know what it may be?
