Computer switching off...
- Have Brush Will Travel
- Has thanked: 224 times
- Been thanked: 384 times
Every now and then my comp just down...sometimes once or twice an hour...it wont let me turn it back on again until I have switched it off at the wall for five minutes
Thoughts?
Thoughts?
- Has thanked: 43 times
- Been thanked: 27 times
Re: Computer switching off...
By 'down' do you mean it switches off, no lights or fans running, or stops working but with fans / lights?
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
It may be overheating. If it's been knocked you may have unseated the processor heatsink. Occasionally the heatsink thermal paste looses its adhesion and this too can cause an overheat/shutdown.
It's significant that you have to wait a few minutes, indicating that heat really is the issue.
- Argyll
- Has thanked: 1180 times
- Been thanked: 580 times
I had the exact same problem last year. It turned out my PC was full of dust (nest to dogs baskets) so I hoovered out the inside and it was fine after that.
- These users thanked the author Argyll for the post:
- joinerjohn
- Has thanked: 17 times
- Been thanked: 315 times
Yep, sounds like it's overheating. Give it a good clean out.
- These users thanked the author joinerjohn for the post:
Completely off...all but a small light on the front that always stays on, unless I turn the machine off at the mainsidkhow2diy wrote:By 'down' do you mean it switches off, no lights or fans running, or stops working but with fans / lights?
Would it begin to cool that quick?It's significant that you have to wait a few minutes, indicating that heat really is the issue.
Ok...thats for the help and advice gents...I will go for the cleaning option first as its the simplest (and cheapest ) and then see how it goes
I'll also check the componants too...I have had a couple of black screen starts mentioning not finding the hard drive..naturally I shat myself the time time it came up as I have had a hard drive fail in the past...luckily I'd backed everything a few days before
But after checking the connections and giving the wires a wobble it was fine
Cheers
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2576 times
My old computer used to do that. Like yours, for no reason what so ever on boot up it could not find the HD, but switch off and back on again.......booted no problem. Never did find out why. It was win xpHave Brush Will Travel wrote:I'll also check the componants too...I have had a couple of black screen starts mentioning not finding the hard drive.............
Cleaning is the first thing to do but while you are in there power it up (fingers out!) and make sure any fans you see are actually spinning up. The PSU (the block the power lead goes into) probably has one, the CPU typically also has a fan - though some CPU cooling is by copper pipe to a fan elsewhere. The graphics card (if there is a separate one) may also have a small fan (up to a pair of large fans if you have gaming PC) and there may be one or more additional fans in the case itself.
If it still does plays up after that many PCs have stuff in the BIOS that will monitor the temperature of various bits, and even the speed of the fans. So if de-fluffing is not a cure let us know the type etc and we'll probably be able to tell you what to press to monitor the temperatures.
Oh, one other point. Even if it's fluff-free it still needs airflow, so if the computer case is up against stuff that prohibits air flow move it away. My wife fried a NAS by stacking magazines against the back...
- These users thanked the author idkhow2diy for the post:
- Someone-Else
Sorry, what is a NAS ?idkhow2diy wrote: My wife fried a NAS by stacking magazines against the back...
Oops - Network Attached Storage - basically a hard disk attached to your house network that anything can use as storage.someone-else wrote: Sorry, what is a NAS ?
- Someone-Else
idkhow2diy wrote:Oops - Network Attached Storage - basically a hard disk attached to your house network that anything can use as storage.someone-else wrote: Sorry, what is a NAS ?
Bit late about keeping my fingers out...'oh whats this?'....ZZZZZZZZZZZZuuzzzzzzzz!!!!idkhow2diy wrote:Cleaning is the first thing to do but while you are in there power it up (fingers out!) and make sure any fans you see are actually spinning up. The PSU (the block the power lead goes into) probably has one, the CPU typically also has a fan - though some CPU cooling is by copper pipe to a fan elsewhere. The graphics card (if there is a separate one) may also have a small fan (up to a pair of large fans if you have gaming PC) and there may be one or more additional fans in the case itself.
Ive actually had the side off for a couple of weeks because I got fed up with undoing the screws all the time...all fans are working though.
I should have mentioned ive done it a few times just after I turned it on..
- Untitled-1.jpg (177.63 KiB) Viewed 3631 times
- kellys_eye
Internal temperatures vary a LOT during use - processor intensive programs tend to consume a lot more power therefore create a lot more heat. A typical intensive action is simply watching Youtube videos! though gaming and rendering images in software is often highly heat-making too.
If your PC is starting to miss-boot it is likely a sign that some power supply capacitors are starting to dry out. This is a very common problem and can usually only be fixed by motherboard replacement (not many people have the skill sets to replace the individual parts).
Make sure you keep regular backups of important stuff and prepare to upgrade the whole shebang....
Its good news week!!!..........lolkellys_eye wrote:Internal temperatures vary a LOT during use - processor intensive programs tend to consume a lot more power therefore create a lot more heat. A typical intensive action is simply watching Youtube videos! though gaming and rendering images in software is often highly heat-making too.
Ok, ok cheers mate, I was planning on a new one sooner..might be sooner tn later now!...
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Overheating is one cause but going by your posts and temps I'd be looking very closely at the power supply..................
- These users thanked the author Razor for the post:
