Tiles on polysafe flooring in wet room
anneishere
Has thanked: 6 times
Post by anneishere »
Can you lay tiles direct on polysafe flooring in a wet room or will it have to be ripped up :scratch: Thanks
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: Tiles on polysafe flooring in wet room
Post by philprime »
Personnally it all depends in what tiles you want to lay, also the condition of the current flooring
I often lay polyflex tiles over polysafe flooring
anneishere
Thank you for reply - we were hoping to lay pebble tiling but will look into polyflex tiling
philprime
Post by philprime »
If your current flooring is in good condition and fixed down properly with no lifting areas, you can lay over the top of it, with the correct preparation
Return to “Tiling Forum”
