I had a NEST thermostat installed which in my case is requiring the thermostat to be plugged into the main power supply by a USB adapter at all time.
I want to hide completely inside the wall the USB cable AS WELL AS the adapter to main which it will be connected to so that at the end I only have a wall plate to look at.
Any idea is there any product designed that way? I am just struggling finding anything on the web.
Thanks in advance for your time and help!
THomas
Hide USB socket (and cable it will connect to) in the wall
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2576 times
Re: Hide USB socket (and cable it will connect to) in the wa
Doubt you will find it since it will over heat, and may cause a fire. BUT you may want to consider one of
