Had a ring last week about repairing a handrail in a communal hallway.
The agent sent through a couple of photos, nice little job really, re-weld and re-polish a couple of joints.
No wonder it came adrift. The handrail serves about 10 flats, so gets a fair bit of use..
The knuckle part is the type that inserts into the tube, and is usually loctited in place. These were pushed in and had two tiny tacks holding them in which had broken on some joints. No sign of any loctite on any of the joints, all flopping around in the tube.
The spigot is threaded into the painted lower part of the handrail, and welded to the tube.
I use the term welded loosely!
Looks like a bit of an attempt at TIG welding, only on one side, so would break off very easily if pushed againt the weld.
The pics are before I did the repair btw
Stainless handrail
- Has thanked: 77 times
- Been thanked: 335 times
Stainless handrail
- 20160219_101159.jpg (174.04 KiB) Viewed 9242 times
- 20160219_101138.jpg (160.68 KiB) Viewed 9242 times
- These users thanked the author Hitch for the post (total 2):
- ultimatehandyman • smujytradeservices
- Rating: 14.29%
- Has thanked: 105 times
- Been thanked: 878 times
Re: Stainless handrail
I think they let the trainee loose on that or it was a Friday job
Its just like our neighbours wrought (reads mild steel) railings the bloke couldn't weld so he put a few self tappers in it then glued it together with araldite
- Has thanked: 58 times
- Been thanked: 18 times
- Been thanked: 1 time
- smujytradeservices
- Has thanked: 10 times
- Been thanked: 4 times
Would like to see the after pics after you did your job. Thanks for posting though.
- These users thanked the author smujytradeservices for the post:
- aaronsussex
