10mm bow in wall
pompeyjim
Has thanked: 9 times
10mm bow in wall
Post by pompeyjim »
I have never tiled before, but about to tile the bathroom.
A problem wall has been dot and dab plaster boarded but it still has a slight inwards bow in the middle.
The wall is exactly 2.4 m high and bows in by 10mm towards the middle.
Can I get away with this amount by using more tile adhesive or is it better to rip the plasterboard off and do it again?
You can't see the curve and it is only noticeable when a straight edge is against it.
Cheers
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: 10mm bow in wall
Post by wine~o »
10 mm is way too much to make up with adhesive.... Probably not what you want to hear..
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Post by steviejoiner74 »
What size of tiles are you going to use? Depending on what type of tile you use its possible to sweeten them out. Most walls ain't mm plumb or straight.
You can add a mm or two of adhesive over a few tiles to sweeten it out so it's never going to be noticeable but it's easy enough for a pro tiler to do but not so easy for an amateur if you get my drift.
Return to “Tiling Forum”
