I've just realised after 5 years that my shower panels have protective film over them! (Often wondered why they would never wipe clean properly)
I've managed to remove a strip revealing the shiny surface below but the strip split and I now cannot find a new edge to remove the rest of it
Any ideas how I can get this off?
How to remove protective film from shower panels
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Re: How to remove protective film from shower panels
Try working at it with the corner of a credit card.
Thanks for the suggestion but still no joy.
I had been remove the seal around the edge of the bath when a bit of the film came loose and I had pulled it off. The remaining fill just appears to be so thin and you can barely feel the edge with your fingers, I had been trying using a Stanley blade.
Someone mentioned putting duct tape over the edge and then the film might lift when it is removed
