Make your own Mallet
- Has thanked: 13 times
- Been thanked: 13 times
I know that for many, it is probably more economic to nip down to B&Q or Wickes, and buy a Mallet, but here in Colombia, I have spent four years searching for one, and eventually gave up, I ordered a beech one from Amazon, but with import duties and transport, it cost more than double the list price, I also wanted another with a bit more weight. I hate using a hammer with chisels, so it was time to do something about it, as I have plenty of scrap mahogany.
I cut the handles on the bandsaw, and shaped them, this gave me the size of the holes I needed to cut in the heads. I then cut the holes in the heads, using firstly a forstner bit in my pillar drill, to take out most of the waste, and finished it off with mallet and chisel. I left the two heads in one piece, until these were completed, as it made the timber easier to handle.
I then cut the heads on my compound mitre saw with a 5° angle on the face, sanded all the parts, rounding the handle to make it a more comfortable fit in my hand, put a slight chamfer around the faces, then after assembly gave them both a coat of mineral oil.
I am glad I made two, because I have since noticed a hairline crack in the face of one, which I am sure will split in time, if it does it will be no loss, after all, it was only scrap!!
- Has thanked: 58 times
- Been thanked: 18 times
- Has thanked: 1300 times
- Been thanked: 1175 times
Re: Make your own Mallet
Nice mallet!
I made one some years ago after reading an article in one of the mags. It was a cheat
. The head was made from four pieces of beech which I had from making my bench, glued together to make the 'ole for the 'andle without any chopping out, it worked OK, and IIRC according to the article the one the writer had made had lasted for some years with no mishap. I gave it away so don't know what happened to mine. I did use it though.
I already had (and have) my dad's mallet though from the 60's which still has "5/11" or something in pencil on the end of the handle.
FWIW I actually prefer a round "carvers" type mallet for bench work. I don't like plastic handles, but I have some for general work around the place, and I'm afraid I tap them with the side of the claw hammer these days. One less tool to carry. You can see why the site boys do it.
Thanks Dave... I certainly wouldn't describe making a mallet from separate pieces a cheat, it is an alternative method, especially if you want to use different types of wood in the build, there are plenty of youtube videos showing both methods. I know what you mean about using a claw hammer, and until recently I had no option, because I had no mallet, but personally I feel as if I have more control with a mallet than a hammer, also you are less likely to damage the handle of the chisel, but with cheap jobbing chisels I guess that is no great loss.Dave54 wrote:Nice mallet!![]()
I made one some years ago after reading an article in one of the mags. It was a cheat. The head was made from four pieces of beech which I had from making my bench, glued together to make the 'ole for the 'andle without any chopping out, it worked OK, and IIRC according to the article the one the writer had made had lasted for some years with no mishap. I gave it away so don't know what happened to mine. I did use it though.
Funny thing preferences. I don't particularly have a problem with using a hammer from an actual physical POV, but it feels "wrong" somehow.
An old joiner I met years ago, despised plastic handles and hitting them with the hammer. He used a cross pein hammer as well. That was back in the 70s, and he was past retirement then, so I'll have a guess he did his time in the 20s. A very different world.
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
But traditionally a site carpenter would have had a set of registered mortise chisels - the sort with a steel ferrules round the tops of the handles (a bit like Japanese chisels) which were specifically designed to be struck with a steel hammer for heavy work - I've actually found two of these under floors on the present job left, no doubt, by long dead carpenters. Those handles, often of ash to withstand the pounding (hickory was American and expensive) could be specified for most types of chisels, although the tool makers advised against it for lighter tools such as bevel edge chisels because they (in particular) were much lighter than the modern, lumpen variety and consequently weren't designed to be belted by a big lump of cast steel. One reason you see so many bent examples at flea markets, I suppose. That trad site carpenter would also have had a set of firmer chisels (his mainstay) which would have wooden handles and be hand "driven", but only a few bevel edge chisels (lighter, more delicate/fragile) and maybe only a couple of paring chisels. The "cross pein" hammer (your engineering heritage is showingDave54 wrote:An old joiner I met years ago, despised plastic handles and hitting them with the hammer. He used a cross pein hammer as well.
Incidentally I recently took a roll of registered chisels, firmer chisels and a couple of paring chisels to a job where I needed to do some more traditional work. It fair freaked out the 2nd year apprentice
The guy was working when I met him. Putting fire doors on an amenity block, meals room, showers etc. I was doing some work near there and got talking. He was IIRC semi retired then, and a bit miffed at being dragged off the bench to hang these doors. The gist was that these doors were special in some way, which they may well have been, (They were massively heavy and had big jamb closers on them. They opened straight out onto a continuous production line.) and the younger blokes couldn't be trusted to do the job properly. I wasn't much into woodwork back then, but (again IIRC it's nearly 40 years ago) he had firmer chisels and, as you say a Warrington hammer and pincers.
You're right, the engineering background still shows. I've rarely had to talk about woodwork really, mostly working alone, so I tend call things what I think of them as.
- Retired
- Has thanked: 2019 times
- Been thanked: 588 times
Nice work PhilCop; isn't it wonderful to use something you've made yourself?
Thanks for sharing.
Kind regards, Col.
Thanks for sharing.
Kind regards, Col.
- Job and Knock
Ah! So a bench joiner. Some of those guys really hate site carpenters - and the conditions you have to work in out in the real worldDave54 wrote:He was IIRC semi retired then, and a bit miffed at being dragged off the bench to hang these doors.
- Has thanked: 201 times
- Been thanked: 515 times
I've got a couple of the traditional mallets . Once many years ago an apprentice asked to borrow my mallet which I was ok with. He looked after it but I found that one mallet between two ( and sometimes three or more as others borrowed the mallet too ) resulted in me not having a mallet when I wanted it. So I ended up knocking one up quickly , and I do mean quickly . An off cut of semi green oak about four inches square or so with a piece of broom handle . Almost embarrassingly I've still got it and still use it.
Another mallet i use is made from a piece of yew. A simple branch around three inches in diameter , bark removed and one end thinned down so the whole thing looks like a wine bottle.
