Hello
I have a garden fence which doesn't span the entire length of my garden. My neighbours shed covers the gap but they are moving soon and the shed may get removed by the new occupants so i want to move this fence along
Currently i have wooden posts which i want to replace with concrete ones. Question is:
By the wall where i want the first post the ground is concrete. What is proper procedure here? Should i dig and bury the post as i will with all the others or just buy a shorter one and bolt it to the wall? Or maybe both?
Would it be ok to dig so close to the wall? Would be filled in with postcrete afterward anyway.
Any suggestions appreciated
Fence post next to wall
- Has thanked: 8 times
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Fence post next to wall
Cut it and bolt it to the wall.
- Has thanked: 58 times
- Been thanked: 18 times
personally, without a photo I could be fully sure, but in my humble opinion, the more solid the better. New occupants might come with a big dog, that needs a solid fence.
Photo supplied
- 2016-05-20 14.45.14.jpg (169.59 KiB) Viewed 2659 times
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
If you are screwing a fence post to a wall put a couple of washers between the post and the wall..
