Turning door and casing want to check
Jaeger_S2k
Pro Handyman
Has thanked: 20 times
Been thanked: 27 times
Post by Jaeger_S2k »
I've got to turn a door round in the office with the shelves where the shelves where built.
I'd like to check my plan? :-)
Remove door.
Remove architrave.
Strap bottom of door casing by pinning a piece of wood across, to hold casing square.
Remove fixings and any packers.
Turn casing and fit packers and ensure vertically true.
Fix casing, fixing through or close to packers.
Rehang door.
Refit architrave.
Repair any plaster around architrave.
Done.
Jaeger.
chippymike
Has thanked: 16 times
Been thanked: 9 times
Post by chippymike »
personally all id do is re hang the door on the other side spin the latch round so it works once uve rehung the door and set the stops. job done
ellie
Post by ellie »
chippymike wrote:personally all id do is re hang the door on the other side spin the latch round so it works once uve rehung the door and set the stops. job done
That depends if the door lining as lose slam strips.
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
Jaegs, am I missing something?, why would you want to remove the architraves?......
By eck! ©
Jaeger_S2k
Pro Handyman
Yeah?
That'd be easy but the 'slam strips' are part of the casing.
Gadget, to get to the fixings?
Jaeger.
Gadget
Jack Of All Trades
Post by Gadget »
Jaeger_S2k wrote:Yeah?
Gotcha, so I guess it's an older property?
By eck! ©
Jaeger_S2k
Pro Handyman
The architraves are nailed to the casing.
Jaeger.
Has thanked: 736 times
Been thanked: 2341 times
before you remove it check the frame for how out of square it is
if the door /frame leans to the side by say one inch top to bottom when you turn it round it will be 2 inches out if you move it to average the gap around the frame you would have to cut 1/2 inch off the skirting one side then add 1/2" the other side
basicly what i am saying is it could be more difficult than it first seems
requiring hammer and chisel and spare skirting ect
another point to consider your colour scemes will be transposed on the door
dirtydeeds
Craftsman Carpenter
Been thanked: 1 time
Post by dirtydeeds »
a piece of wood will not ensure your lining is square
traditionally you plaster before installing the architrave
chippymike
sorry i thought you meant lining with lose stops
Jaeger_S2k
Pro Handyman
OK. Door and casing turned.
Mad half hour trying to work out why the door (on the lock side) was flush fit at the bottom and up about 12" then leaned away from the jam, leaving a slither of a gap (which slithered to about 1/2" :shock: ) at the top.
Check and check and check,
Casing square (Check)
Casing Plumb (Check)
After scratching head, saw the door from a distance, it was warped!
The swap went quite well and was a good experience. The case was packed at one side and not the other, so some skirting was trimmed (MultiMaster to the rescue) and the floor covering varied too so needed trimming one side, I'll be packing and filling the other later.
All in all I'm pleased with it so is the client, will get photo's on next visit.
Thanks to all who responded.
Jaeger.
