H.W. cylinder insulation
Energy saving questions in here please
torquie
Post by torquie »
I would be grateful for an answer to these simple questions.
I have a 20 year-old three bedroomed bungalow, with an airing cupboard containing the gas-fired boiler and the indirect, foam insulated hot water cylinder for water and central heating.
This airing cupboard gets unnecessarily warm so I have recently fitted a Marley (?) four-piece tied-on insulating jacket to the cylinder.
Do I need to cut a hole in this added insulation to help keep the Sunvic clamp-on thermostat cooler?
Is there a recommended temperature setting for this thermostat?
Many thanks.
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: H.W. cylinder insulation
Post by steviejoiner74 »
Does the cupboard door have a vent on it?
An insulated cylinder wouldn't normally be insulated as the cost of putting a jacket over it might outweigh any potential savings you may make. Especially if the hot water is used frequently.
torquie
Post by torquie »
Oh dear - I thought that I should know whether there is a vent. I will have to sketch it and come back to you.
I am not too bothered about the cost of the added jacket - I just didn't like the thought of the excess heat from the cupboard escaping into the loft.
The water is not used what you might call 'frequently'.
Thanks.
torquie
Post by torquie »
There is a 22mm o.d. copper tube leading from the side of the Ideal Mexico Slimline gas boiler to an open-ended 360 degree turn over a small plastic tank in the loft. So I guess that it is a vented system.
There is a vent in the ceiling of the airing cupboard, leading into the loft.
Should I cut a hole in the extra insulation to help keep the Sunvic clamp-on thermostat cooler?
Thanks.
Return to “Energy Saving”
