Lidl Thursday 25th August
- Has thanked: 61 times
- Been thanked: 319 times
Circular Saw £35
2000w Table Saw £100
Discs £4
Vice £20
Diamond Drill bits and guide £6
SDS plus Drill £40
SDS Masonary drill bits £12
50 piece drill bit sets £8
Racking £35
Ratchet bit and socket nut set £13
Crimping pliers £8
5 in 1 Detector £17
Multimeter £10
Digital caliper and Angle finder £10 each
Cable reel £10
http://www.lidl.co.uk/en/our-offers-2491.htm?id=924
Discs £4
Vice £20
SDS plus Drill £40
Racking £35
Crimping pliers £8
5 in 1 Detector £17
Multimeter £10
Cable reel £10
- These users thanked the author boxedin for the post (total 2):
- big-all • Job and Knock
- Rating: 14.29%
- Wind Gatherer
- Has thanked: 46 times
- Been thanked: 1 time
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Re: Lidl Thursday 25th August
Thanks Did anyone notice that there are circular saw blades - 160mm diameter x 2.2mm kerf (42 and 48 tooth)?
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Did anyone notice the saw blades look like Bill & Ben and Weed in the middle.
- Has thanked: 109 times
- Been thanked: 1038 times
If they are like last time though the blades are 30mm bore so don't fit my track saw :(
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Can you not use a bore adaptor?Rorschach wrote:If they are like last time though the blades are 30mm bore so don't fit my track saw :(
Nope the arbour of the saw is only 30mm with a 20mm step for the blade. If I use a bore adapter the blade will fit but there is no bearing surface touching the arbour, as soon as you spin it up the blade would come loose.steviejoiner74 wrote:Can you not use a bore adaptor?Rorschach wrote:If they are like last time though the blades are 30mm bore so don't fit my track saw :(
