beading (wooden floor)
Help!! what is the angle when you are going around a door frame?? I have tried the 45 degree but they just dont join up... I dont want to waste anymore as its expensive...
- dirtydeeds
- Craftsman Carpenter
- Been thanked: 1 time
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Might be a bit late now, but it's best to go underneath the door frame if possible-
http://www.ultimatehandyman.co.uk/lamin ... frames.htm
Only asked for a photo I know how to cut mitersdirtydeeds wrote:ellie
a 45 degree mitre ONLY works if the angle is 90 degrees AND the lining is EXACTLY square to the wall
if the lining isnt exaclty flush to the wall you are dealing with a compound angle
practice is the only teacher, it isnt easy and 99% of all architraves have this problem. its a fact of life
