Caleffi trv valve head replacement
Sparky70
Has thanked: 157 times
Been thanked: 1 time
Post by Sparky70 »
Hi, is it possible to change just the trv head for a different manufacturer or should it be like for like? I have been searching on the Web but they don't seem easy to find, can anyone point in the right direction. Reason for change is that it's dicoloured.Image
Sent from my SM-G901F using Tapatalk
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Re: Caleffi trv valve head replacement
Post by thescruff »
Sparky70
Post by Sparky70 »
Thanks for the links but is it possible to use a different brand?
thescruff
Post by thescruff »
You'd need to try it, but unlikely would be my best guess.
Perhaps if you contact the first link they May tell you what is interchangeable.
These users thanked the author thescruff for the post:
Sparky70
Sparky70
Post by Sparky70 »
Also do you know about these? I was sent 22mm in error through eBay and I can send back for a full refund, I'm going to use it for washing the dog in the garden. Instead of sending it back could I not fit some 22 to 15mm reducers without affecting performance? They have offered me a bulldog mixer which is apparently the same.
Sparky70
Post by Sparky70 »
thescruff
Post by thescruff »
Yes An Endex 22x15 N6 will fit straight into the compression fittings, ( need to solder the 15mm end)
YS6 is the same fitting with solder rings, so clean, flux and heat.
The valve should be ok for what you want with a controlled temperature, best fit isolating valves on the hot and cold inlets
Sparky70
Sparky70
Post by Sparky70 »
thescruff wrote:Yes An Endex 22x15 N6 will fit straight into the compression fittings, ( need to solder the 15mm end)
Is it worth sending back for the bulldog valve or just keep this one and use your recommendation? Also this unit comes with non return valves, I would need to Install two single check valves for wras?
thescruff
Post by thescruff »
You have it I would use it, there isn't a lot of difference in price if I remember.
If the check valves are built in you don't need additional ones. If anything fit a check just before the handset hose
Sparky70
Sparky70
Post by Sparky70 »
thescruff wrote:You have it I would use it, there isn't a lot of difference in price if I remember.
Many thanks for your help Scruff.
