Washing line
- Banned- Hacked account
- Has thanked: 6 times
- Been thanked: 6 times
Washing line
When we had our garden landscaped. I asked for the washing line post to be taken out as it was unsightly
I dot really want another one out in if I can help it and was wondering if I can use one of the fence posts that have been concreted in?
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: Washing line
Of course you can. You can buy retractable (Sp?) washing lines on a reel as well...
Re: Washing line
I have the reel. I was just meaning that if I tie the other end to the fence post instead of metal post....will the fence come downwine~o wrote:Of course you can. You can buy retractable (Sp?) washing lines on a reel as well...
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2575 times
Re: Washing line
Would that not depend on the weight of the washing (Wet washing is heavy) and how well the fence post is mounted?
Why not opt for a rotary washing line?
- wine~o
Re: Washing line
If the post has been concreted in properly it won't move under the weight of a bit of washing...
- Someone-Else
Re: Washing line
Agreed, but it also has at least one maybe two fence panels on it as well.wine~o wrote:If the post has been concreted in properly it won't move under the weight of a bit of washing...
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Washing line
A 4x4 fence post concreted in 2 ft won't budge with some washing on it.
Re: Washing line
Fingers crossed then lolsteviejoiner74 wrote:A 4x4 fence post concreted in 2 ft won't budge with some washing on it.
It's a double line I have so I'll make sure to tie them off onto different posts
- Has thanked: 818 times
- Been thanked: 3514 times
Re: Washing line
A prop is essential as it reduces the load at each end and also lifts the washing up avoiding the line sag.
We have a rotary line now that is kept in the garage when not in use.
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Re: Washing line
My bachelor line and prop works good, even in hi winds, though the 5' bed sheets need doubling. And spot the immersion wrench, haha!
- WashingLine.jpg (48.25 KiB) Viewed 3526 times
