Led lamps with dimmer
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
Planning to install a 5 lamp chandelier with dimmable virtual filament lamps. But the dimmer switch I have is rated at 400watt max, 60watt upwards. The 5 lamps are nowhere near that greedy. Are dedicated LED dimmers available, or do I have to use one ordinary incandescent lamp in the mix?
steviejoiner74
Has thanked: 747 times
Been thanked: 1616 times
Re: Led lamps with dimmer
Post by steviejoiner74 »
I had 6 LED downlights installed in my boys room and the wife wanted a dimmer switch. My sparky mate did the work but he had to get a dimmer switch that was compatible with the LED downlights and it cost around 25 quid(ish) if I remember.
These users thanked the author steviejoiner74 for the post:
Mooncat
Mooncat
Post by Mooncat »
Used my initiative,(should have done that first) and found this:
https://www.downlights.co.uk/led-dimmer-switch.html
less expensive than using incandescent! :thumbright:
dave_s
Post by dave_s »
I've heard good things about the Varilight V-PRO range of dimmers from my sparky friend in case it's of use :)
Mooncat
Post by Mooncat »
The cat is back! I hope I am still welcome.
I finally got my house, most of my stuff is there as well. I'll be installing the chandelier, or should I say electrolier as it has no candles, in February.
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
DYOR, trailing edge & leading edge dimmers - it's something to do with AC current I can't get my head round.
Has thanked: 47 times
Been thanked: 2590 times
arco_iris wrote:DYOR, trailing edge & leading edge dimmers - it's something to do with AC current I can't get my head round.
Its not that bad.
A.C. Is alternating current
If you could see it, you would see a sine wave just like the one below
This sine wave is "moving" at 50 times every second.
A dimmer works by switching off the electricity.
A leading edge dimmer switches off just as the sine wave starts to "rise"
A trailing edge dimmer switches off just as the sine wave nearly "ends"
It takes a lot more electronics to make a trailing edge dimmer than it does a leading edge dimmer, so that is why most dimmers are leading edge, just because it costs less, and the fact when they were invented, trailing edge dimmers were not needed.
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Post by wine~o »
Mooncat wrote:The cat is back! I hope I am still welcome.
We all thought you had shuffled off this mortal... :wink:
:huray: on the house move
Mooncat
Post by Mooncat »
It is taking longer than I hoped, but I have some lives left, I hope. I am back in Wales until the end of February. I'll post some pix elsewhere.
Return to “Lighting”
