Makita 18v Li-Ion combi drills and drill drivers (10/2016)
Makita power tool reviews in here please
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
I'm sure that I'm not alone in being confused by Makita's model numbers, so this is an attempt to help anyone interested in buying a Makita 18 volt combi drill or drill/driver. This only covers the Li-Ion range currently on the market and available (6 Nov 2016), not the now defunct NiCd and NiMH products. Earlier models which are no longer available such as the DHP451, DHP452, etc are also omitted. The categories are all mine but are an attempt to make sense of the type of work these tools should be expected to perform. As ever combi drills cannot be regarded as a replacement for even a basic SDS drill when drilling masonry (although te wo heavy duty models get pretty close) so if you want to use a lightweight combi to drill masonry in a trade environment don't be surprised when it dies prematurely. For drilling heavy metalwork such as structural steels on a regular basis or for regular hole sawing greater than 65mm I'd recommend a model with a metal gearbox AND a metal chuck - nothing else will withstand the stresses and strains of that sort of work
Combi drills (drills with a drilling, impact drilling and torque adjustable screwdriving setting) are all prefixed "DHP" in the UK
Drill/drivers (drills with a drilling and torque adjustable screwdriving setting) are all prefixed "DDF" in the UK. In general these are slightly lighter than the DHP variant (about 50gm). For some (not all) DHP model there is an equivalent DDF model, but they are less commonly sold and generally cost more.
Colours: Standard colour is Makita blue. Special edition models have been sold in white, red, black and metallic blue (only DHP456 and DHP481 AFAIK). The metallic colour is a sprayed finish and not hugely durable (white is a plastic colour)
In general and in common with other cordless tools most models feature plastic gearbox housings and chucks (exceptions are noted). AFAIK all Makita models use metal gears. All of Makita's drills now have 2-speed mechanical change gearboxes
Current production models appear to be: DHP458, DHP459, DHP481, DHP482, DHP483 and DHP484
Information has been checked against Makita official information. E&OE
* indicates models which have been superceded
Basic DIY models:
Model: *DHP453 - Basic DIY combi drill
Motor: Brushed
Speeds: ~400, ~1300
Capacities:
Wood: 36mm
Masonry: 13mm
Metal: 13mm
Torque: 42Nm
Weight: 1.7kg
Updated version of BHP453. No DDF equivalent avalable. Replaced by DHP483
Model: DHP483 - Basic DIY combi drill
Motor: Brushed
Speeds: ~400, ~1700
Capacities:
Wood: 36mm
Masonry: 13mm
Metal: 13mm
Torque: 40Nm/23Nm
Weight: 1.6kg
Replaces DHP453. No DDF equivalent avalable. New model 2016
DIY/light trade models:
Model: DHP459 - DIY/light trade combi drill (brushless)
Motor: Brushless, basic
Speeds: ~400, ~1500
Capacities:
Wood: 38mm
Masonry: 13mm
Metal: 13mm
Torque: 45Nm/25Nm
Weight: 1.7kg
Entry level brushless combi. No DDF equivalent avalable. Probably somewhere between DHP453 and DHP456 in terms of performance
Model: *DHP456 - DIY/light trade combi drill
Motor: Brushed
Speeds: ~400, ~1500
Capacities:
Wood: 38mm
Masonry: 13mm
Metal: 13mm
Torque: 50Nm/36Nm
Weight: 1.8kg
Updated version of BHP456 which in turn was an improved of the BHP452. DDF equivalent was available. Recently replaced by DHP482
Model: DHP482 - DIY/light trade combi drill
Motor: Brushed
Speeds: ~400, ~1500
Capacities:
Wood: 38mm
Masonry: 13mm
Metal: 13mm
Torque: 62Nm/36Nm
Weight: 1.8kg
Replacement for DHP456 which in turn was an improved of the BHP/DHP452. New model 2016
Trade models:
Model: *DHP480 - Trade combi drill (brushless)
Motor: Brushless
Speeds: ~400, ~1500
Capacities:
Wood: 38mm
Masonry: 13mm
Metal: 13mm
Torque: 54Nm/36Nm
Weight: 1.6kg
DDF equivalent was available. Recently replaced by DHP484
Model: DHP484 - Trade combi drill (brushless)
Motor: Brushless
Speeds: ~400, ~2000
Capacities:
Wood: 38mm
Masonry: 13mm
Metal: 13mm
Torque: 54Nm/30Nm
Weight: 1.6kg
Replacement for DHP480. New model 2016
Heavy duty trade models:
Model: DHP458 - Heavy duty combi drill
Motor: Brushed
Speeds: ~400, ~2000
Capacities:
Wood: 65mm
Masonry: 16mm
Metal: 13mm
Torque: 91Nm/58Nm
Weight: 2.3kg
Heavy duty replacement for the original BHP/DHP481 combi drill. Most powerful brushed model in the range
Model: DHP481 - Heavy duty combi drill (brushless)
Motor: Brushless
Speeds: ~400, ~2000
Capacities:
Wood: 65mm
Masonry: 16mm
Metal: 13mm
Torque: 115Nm/60Nm
Weight: 2.7kg
Brushless equivalent to DHP458 with improved torque. DDF version is available. Most powerful brushless model in the range and a real beast!
These users thanked the author Job and Knock for the post (total 3):
big-allStealthwolfcoofercat (Mon Aug 19, 2024 10:07 am)
Rating: 21.43%
Has thanked: 734 times
Been thanked: 2333 times
Re: Makita 18v Li-Ion combi drills and drill drivers (10/201
thanks for taking the time and effort to compile a comprehensive guide that will hopefully help many :thumbright:
Return to “Makita”
