Timber and steel table
- Has thanked: 77 times
- Been thanked: 335 times
We wanted a little side table to go at the end of the sofa, something to match the other furniture I made a while ago, so knocked this up over the Christmas break. :)
5 sections plasma cut from 3mm thick steel sheet, fixing tabs folded, then strips welded on to join them.
A quick burnish and lick of matt black...
Timber sections kncked up, waxed and screwed on...
Col/Retired I video'd one of the sections being cut out if you want me to send the video let me know....
- tabbridge3.jpg (172.03 KiB) Viewed 6443 times
- tabbridge2.jpg (161.84 KiB) Viewed 6443 times
- tabbridge1.jpg (146.43 KiB) Viewed 6443 times
- These users thanked the author Hitch for the post (total 7):
- ultimatehandyman • Cannyfixit • darrenba • BillyGoat • OchAye • boxedin • Retired
- Rating: 50%
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2575 times
Re: Timber and steel table
Is it modelled on "iron bridge"? looks like it, very nice too.
someone-else wrote:Is it modelled on "iron bridge"? looks like it, very nice too.
Yes, certainly is. Subtly changed at the top to accommodate the table top. Other than that, I tried to keep it as near as practical.
- Has thanked: 1300 times
- Been thanked: 1175 times
It makes a great looking table Hitch. You've got a good eye for work like that.
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
Nice piece of furniture Hitch,
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
very nice. Don't let the Mrs. see this she'll want one..
- smujytradeservices
- Has thanked: 10 times
- Been thanked: 4 times
An amazing design again. The realisation of your vision is equally as impressive. Enjoyed looking at the photos for ages.
- Retired
- Has thanked: 2019 times
- Been thanked: 588 times
Many thanks Hitch yes would appreciate the video please. Top job on the table and immediately I saw it I too thought "Ironbridge" what type of fork-truck do you move it around on? You must have had a heck of a lot of waste from the steel sheets but it sure looks worth it seeing the end result; I bet you spent ages fettling the sharp edges. full credit to you; beautiful and functional whilst being truly unique.
Kind regards, Col.
Kind regards, Col.
Just uploading the video of one section to YouTube Col.
Wastage wasn't much really, all 5pieces came from less than half of a 2x1m sheet of 3mm. Nested inside each other to save wastage. The sheet is pretty cheap, about £25/30 for a whole sheet.
The cut was pretty clean tbh, a few bits just to knock off with a file here and there, then to ease the edges slightly I just worked a twist knot cup brush over the sections. If u was to make another I'd probably pay slightly more attention to cleaning up the cuts. Once the tabs were folded I just tacked it all together starting at the middle and worked out using a piece of box section as a spacer. A quick coat of primer followed by some matt black. Took me about 3 hours to make and paint the metalwork. That's excluding doing Cad.
https://youtu.be/4tNthzvNads
Hopefully that works.
- wine~o
2:56 in that video... removing a bit of chaff......Hitch wrote:https://youtu.be/4tNthzvNads
I wouldn't have a hand anywhere near that beast...
No real issues, if the head gets knocked by a piece of metal or hand or whatever, it stops dead in its tracks... and can be a pain to restart in exactly the right place, hence wanting to get the piece out of the way quickly. No issues from the arc either, the bit you dont want your hand in the way of is under the electrode- where the sheet it. Small lightweight part too, so not much heat in the pieces. Normally its ran with water in the table which keeps it cooler still, and absorbs the fume.
- wine~o
Thanks for the explanation.
I don't do big boys toys.....
Interesting video. I've not seen one working. They're after my time in industry.
I know they had one where my mate worked until he retired. He says it's impressive both from what can be done, and the finish.
The nearest we came where I worked was one of those little wheeled device that carried a burning head and ran on a length of track!
