Audi turbo diesel hit and miss on starting
fitzy
CLOSED ACCOUNT
Has thanked: 871 times
Been thanked: 757 times
Post by fitzy »
When I start my car from cold it seems like it's missing until I rev it a few times and it evens itself out.
Also, I've noticed on idle that the engine "jumps" intermittently.
Generally drives ok though.
Sent from my SM-G850F using Tapatalk
Has thanked: 823 times
Been thanked: 3558 times
Re: Audi turbo diesel hit and miss on starting
Sounds like sensor is not working and the ECU is getting the fuel balance wrong. You need to pick up the error codes from the OBD port.
Cantseeitfrommyhouse
Has thanked: 36 times
Been thanked: 108 times
Post by Cantseeitfrommyhouse »
Could be a dead heater plug.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
bad glow plug or a injector
scan for codes, check the voltages and resistance of the plugs then a leak down test to check the injectors
when was the last time the fuel filter was changed/water drained off ?
fitzy
CLOSED ACCOUNT
Post by fitzy »
Bob225 wrote:bad glow plug or a injector
Probably last time it was serviced. So in the last 12 months or so.
Bob225
Post by Bob225 »
I doubt it, unless you requested it, what year is the car ?
fitzy
CLOSED ACCOUNT
Post by fitzy »
Bob225 wrote:I doubt it, unless you requested it, what year is the car ?
2006. 170k on clock.
Bob225
Post by Bob225 »
Do the filter then, they are cheap enough, Crossland one is about a tenner, the better quality one (Bosch) is £15-16
These users thanked the author Bob225 for the post:
fitzy
fitzy
CLOSED ACCOUNT
Post by fitzy »
Cheers mate. As I say, it's due a service so I'll mention it.
Chop
Has thanked: 304 times
Been thanked: 219 times
Post by Chop »
Once youve tried the filter another vote for a glow plug, relatively cheap fix, just working out which one is faulty.
These users thanked the author Chop for the post:
fitzy
:thumbleft:
fitzy
CLOSED ACCOUNT
Post by fitzy »
Chop wrote:Once youve tried the filter another vote for a glow plug, relatively cheap fix, just working out which one is faulty.
Finally got the car serviced this weekend and also did and engine flush and fuel treatment.
The jumping whilst on idle has smoothed out, but the cold start bit still hasn't been totally cured.
Looking through all the receipts there is no mention of the plugs being replaced and with 176k on the clock they must definitely be ready to change.
fitzy
CLOSED ACCOUNT
Post by fitzy »
Latest on this is the car still has a rough idle but now sounds like it's blowing slightly. Sounds like towards the back end of the exhaust. I'm wondering if the two are related?
No loss of power, and still drives well.
fitzy
CLOSED ACCOUNT
Post by fitzy »
And to add to this again, today my exhaust finally gave up the ghost, so I'll soon find out whether or not the rough idle was caused by the exhaust. The blowing certainly was! [WHITE SMILING FACE]
Drove it today and noticed it suddenly sounded louder, followed by a clank.
When I looked underneath, as far as I could see a section had totally disconnected from the front sections.
It's going in first thing fingers crossed.
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Post by wine~o »
fitzy wrote:And to add to this again, today my exhaust finally gave up the ghost, so I'll soon find out whether or not the rough idle was caused by the exhaust. The blowing certainly was! [WHITE SMILING FACE]
Proper garage I hope and not Kwik fit or the ilk ??
fitzy
CLOSED ACCOUNT
Post by fitzy »
Yeah, it's a local garage, so if he lifts the car up and finds it's something minor he'll sort it rather than trying to sell me a complete system like those guys.
I've been doing a bit of googling and it appears that the vw and audi exhaust parts just slot into one another so hopefully it's a quick fix if it's just come apart, which looks to be the case.
I'll let you know how it goes. [emoji106]
