Hot Water
Please post your money saving posts/ideas in here please.
newdud
Has thanked: 40 times
Hot Water
Post by newdud »
Hello
During the summer months when not using gas to heat the house, does it make sense to use the
Electric immersion heater to heat water :dunno:
I have an economy 7 meter, so can heat the tank and night time and probably will last the whole day.
Gas KWh is 3.242p
Economy 7 Elec KWh 9.09p
I am assuming that immersion heater is more efficient?
Any thoughts
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: Hot Water
Post by kellys_eye »
What are your actual needs?
What system is in place to heat water via gas?
Instant hot water (gas or electric) may be cheaper but that would mean paying for a separate system installed.
But using your own figures then gas is obviously cheaper - storage in a well insulated tank helps but I find the needs for hot water are greater in the evening where even the best tanks won't give you all your needs (dishes, bath etc) and an insulated tank doesn't cut the mustard for that length of time and quantity required.
Has thanked: 734 times
Been thanked: 2333 times
Re: Hot Water
your economy electric is not cheap :dunno:
i thought day rates where a bit more but economy was close to gas prices
what are your day rate prices ??
newdud
Re: Hot Water
Post by newdud »
My hot water comes from a Hot Water tank , heated by a system boliler set on a timer. So heat the water twice a day.
Also , during the winter the bolier is used for central heating as well.
On the Hot Water tank, there is a immersion heater plugged in for a backup incase the gas boler fails.
The day rate is 18p KWh
Re: Hot Water
you need to change supplier i pay 11p a kwh all day and all night single rate meter
money saving expert a fairly impartial i would swap
http://www.moneysavingexpert.com/utilit ... lectricity
Return to “Money Saving”
