Tripping out
Posted: Fri Mar 28, 2008 11:42 am
Please can anyone help with this:
Mid 1920s 3 bed semi had a professional total rewire last July and is in the process of refurb. Since then everything has been fine until the other night when the ground floor wiring circuit began tripping out after the kitchen light (circular fluourescent) had been on for about 5 minutes. Other ground floor lights don't cause trip-out.
Switch and light fitting connections were tight. Changed fluourescent tube -still trips out after 5 minutes. I changed the fitting for a conventional bulb and holder and the same thing happens.
On checking the wiring in the ceiling rose the only thing amiss was that the earth wire from the light fitting cable had become detached from the loop-in(?) earth wire, however, reconnecting it made no difference to the problem.
A few days before this problem, I noticed a very wobbly section of floorboard in the back bedroom. The cause was a (new) lighting cable coming from a conduit T junction and which had been passed over the top of the conduit so that the cable lay between the conduit and the floorboard, and so the floorboard could not lie flush. With quite some effort and bother, I removed the T piece so that the cable now lies below joist level. I did not cut into or otherwise disconnect the cable, which I am guessing is the supply to the kitchen.
