Wall tile adhesive, Mapei ok?
The Engineer
Has thanked: 25 times
Been thanked: 4 times
Post by The Engineer »
Hi gang,
Will be applying 300 x 600 wall tiles in the bathroom to Hardibacker or plaster board. Hardibacker in wet area and plasterboard in dry areas.
Would this mapei powder adhesive from Wickes be ok?
http://www.wickes.co.uk/Mapei-Mapeker-R ... g/p/102976
Thanks in advance [THUMBS UP SIGN]
Sent from my Moto G (4) using Tapatalk
darrenba
Has thanked: 104 times
Been thanked: 490 times
Re: Wall tile adhesive, Mapei ok?
Post by darrenba »
It's good adhesive but it's rapid drying and grey. But if you're not used to tiling or have light colour tiles then you'd be better off choosing a standard set white adhesive. I use thisImage
The Engineer
darrenba wrote:It's good adhesive but it's rapid drying and grey. But if you're not used to tiling or have light colour tiles then you'd be better off choosing a standard set white adhesive. I use thisImage
Where can I buy that from? Didn't see it in Wickes
darrenba
Post by darrenba »
I get it from my local independent tile shop
You can use this link to find your local stockist http://www.tilemasteradhesives.co.uk/stockists
The Engineer
Awesome!
toolbox
Has thanked: 131 times
Been thanked: 217 times
Post by toolbox »
Wickes do it in white too if you prefer. http://www.wickes.co.uk/Mapei-Mapeker-R ... g/p/112715
Return to “Tiling Forum”
