3 Batten Lights, 1 Switch
- Has thanked: 1 time
- Been thanked: 3 times
Hello there.
I was looking through some posts here and it seems like there's some helpful people so I thought I'd ask my own question.
I want to put 3 batten lights up in my garage, all to be powered by one light switch by the door. I'ts been a long time since I studied electrics at college so I wanted to check if my wiring plans were correct.
Here's a diagram I whipped up:
Would it work? Is there a better/more efficient way to wire it up?
Many thanks
Ryan
Many thanks
Ryan
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2554 times
Re: 3 Batten Lights, 1 Switch
Yes it will work, but a waste of cable.
If you really want 3 batten holders, wire the first one as per your drawing, then loop the 2nd one from the first one, and then loop the third one from the 2nd one.
It may also be that you have "forgotten" more than you think. You have drawn florescent lights and called them battens.
You should also supply them from a 6A MCB
Above is a batten holder
Above is a florescent
- These users thanked the author Someone-Else for the post (total 2):
- rustylad • multiman
- Rating: 14.29%
@someone-else
Thanks for your reply. I was just going off the names on Screwfix as that's where I bought the gear from. http://www.screwfix.com/c/electrical-li ... cat3640003
Many thanks
Ryan
Edit:
To clarify, is this what you meant?
Edit 2:
On second thoughts, no that doesn't look right.
Many thanks
Ryan
Edit:
Edit 2:
- Someone-Else
But it is right, although it may be easier to loop in and out the same end of the light.
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
have you thought about area lighting ??
as in two or three switches allowing one two or three light in use
@someone-else
So those connector blocks for the neutrals are in the right places? I didn't think lights 1 & 2 would work because there's nothing in their neutral terminals.
@big-all
The garage isn't really big enough to worry about that. Besides, how many more questions do you think I'd have if you threw more switches into the mix?
Many thanks
Ryan
@big-all
Many thanks
Ryan
- Someone-Else
I figured you would be using the choc blocs in the lights, guess I figured wrong.
You loop in and out of each lights connections. The only "extra" choc bloc needed is at the switch.
- Approved Electrician
- Has thanked: 225 times
- Been thanked: 662 times
The correct name for a fluorescent is actually "batten holder".someone-else wrote:Yes it will work, but a waste of cable.
