Removing floor tiles
Dusty45
Been thanked: 1 time
Post by Dusty45 »
HI, We want to replace the floor tiles in our porch - I assume this will damage the wall?
Will we be able to remedy this ourselves or will it mean someone has to come in and do a full wall skim?
Many thanks, Dusty
Grendel
Has thanked: 202 times
Been thanked: 526 times
Re: Removing floor tiles
Post by Grendel »
Unless you're using dynamite to remove the floor tiles there shouldn't really be a problem . The walls and floor can be treated as separate items . Use a bolster and hammer and lift without going mad at it , perhaps start with a drill to break up one tile and then work outwards.
These users thanked the author Grendel for the post:
multiman
davyp1
Has thanked: 13 times
Been thanked: 181 times
Post by davyp1 »
Unless you have a tile 'skirting' which you intend t replace as well?
Then that may present a problem.
davyp1
multiman
Has thanked: 689 times
Been thanked: 28 times
Post by multiman »
You can use grout remover tool some people fuse angle grinder then hammer and bolster the first one is tricky the rest will be easier if you need crack a tile you can hammer on top hope that helps
Has thanked: 833 times
Been thanked: 3636 times
Don't ponce around with a bolster get an SDS chisel drill see http://www.screwfix.com/p/titan-ttb278s ... 240v/97533 Buy the wider chisel (cheaper at Toolstation) and that will make it an easy job. I recommend these so often I should be on commission. Best £60 you can spend :thumbright:
Return to “Tiling Forum”
