zx diesel injector pump leaking
Posted: Sun Apr 06, 2008 9:12 am
by village idiot
anyone know anything about the diesel injector pump on a '96 citroen zx 1.9? (same engine in peugeot)
it's leaking from the throttle stem seal on top of the pump, not much, just a weep but at the end of the day it's still leaking & dripping diesel all over the place :cb
it looks like you can take the top cover off without breaking any seals, & it's probably just a "O" ring needed that's worn, just wanted to find out if anything is going to go "fring" if i take the cover off, & will it need set up again :scratch:
a new pump would probably be more than the car is worth :cussing:
Posted: Mon Apr 07, 2008 9:21 am
by stevemastic
http://www.lsuk.co.uk/ a good place to start
Posted: Mon Apr 07, 2008 10:06 am
by uncle buck
What pump is fitted to the car ? is it Lucas or Bosch?
Here is a guide to striping a Bosch pump:
http://www.eastment.net/Boschpump1.htm
If you have the Lucas pump try asking here:
http://www.frenchcarforum.co.uk/forum/index.php
Posted: Mon Apr 07, 2008 8:45 pm
by village idiot
it's the lucas, have taken top cover off & removed the 2 "O" rings off shaft
will get a couple of new ones tomorrow & hopefully job's a goodun [fingers crossed smiley]
