Morning Everyone..
Tiling bathroom 300 x 500 ceramics , thinking of using backing board prob no more ply , on to brick they recommend fixing with tile adhy dot and dab .
was wondering if anyones used the fixing foam like dow insta stick or pink grip dry fix , i fancy trying it but obviously not if its not up to the job..
and would you go with 6mm or 12mm backer
thanks guys
Flint
- Ultimate Handyman Forum Index DIY Forum/Home improvement Tiling Forum
- It is currently Fri Apr 11, 2025 3:11 pm
fixing Tile Backer to brick
FatFlint
- toolbox
- Has thanked: 131 times
- Been thanked: 217 times
Re: fixing Tile Backer to brick
I have used 6mm on brick with dot and dab (although I added mechanical fixings) but it did flex quite a bit the makers did not recommend it but I was stuck for space.
Not tried the foam but, if it is any help when I found it flexing I drilled extra holes in the boards and squirted a splodge of building adhesive through the holes to add stiffness that worked fine.
toolbox
- Has thanked: 12 times
- Been thanked: 4 times
FatFlint
- toolbox
I used Marmox which has an insulating layer as it was a cold room with two outside walls, but any tile board should do, the Marmox might be overkill in your case.
toolbox
