Wood moisture levels
Posted: Tue Apr 08, 2008 5:31 pm
by Mooncat
Aldi has a moisture testing device on sale this week. It is shown testing damp in masonry, but can also be used with wood. But is oak likely to give the same reading as pine with the same moisture %? And how does temperature affect the readings?
Posted: Tue Apr 08, 2008 6:25 pm
by wood doc
Hi Mooncat
A moisture meter will give the moisture content of any timber you press the probes into, temperature shouldn`t affect the reading, bearing in mind that the moisture content alters with its surrounding over time.
Posted: Tue Apr 08, 2008 11:01 pm
by joiner_uk
I agree with wood doc :thumbright: moisture is moisture the readings should be the same despite material. The only thing to consider is the quality of the equipment you are using.
