Rubber Flat Roofs
All building related posts in this forum please
charliecharlton
Has thanked: 2 times
Rubber Flat Roofs
Post by charliecharlton »
Have just had a rubber flat roof installed on a new extension and when looking out the first floor window can clearly read 1-2mm 70524 FR AG 1211 MADE IN USA is this how it should look or has the rubber membrane been laid upside down and if so does it matter or is it just cosmetic.
Many thanks in advance.
Charlie
wes56
Has thanked: 6 times
Been thanked: 187 times
Re: Rubber Flat Roofs
Post by wes56 »
whats going on with posting replies, i posted reply here yesterdayan its disapeared?
the answer is theres no up or down side to the sheets.
These users thanked the author wes56 for the post:
charliecharlton
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
wes56 wrote:whats going on with posting replies, i posted reply here yesterdayan its disapeared?
SFAIA you are the only regular having this issue.
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
ive done a fair few rubber roofs. i used to lay it with the code words facing down so there was no unsightly writing to be seen.
last time i laid a rubber roof i discovered that the code words were on both sides. so either i got lucky or perhaps a different manufacturer. its a bit mad like but i guess just have to live with it.
These users thanked the author fin for the post:
charliecharlton
Return to “Building Forum”
