how to stop the paint flashing
vlb
Has thanked: 45 times
Been thanked: 7 times
Post by vlb »
Hi Guys, looking for a little bit of advice.
When i am cutting in using a brush, the bit i have cut in always looks darker than the rest of the wall (done using roller)
I believe this is called "flashing" ? (brother in law is P&D and i am sure thats what he called it)
It basically looks like the paint is darker around the bits i have cut in.
Any advice?
Cheers
dubman2
Has thanked: 4 times
Been thanked: 155 times
Re: how to stop the paint flashing
Post by dubman2 »
Its called Framing & not flashing which is a different problem which is usually caused by not priming some fillers before painting so it flashes when light hits the filler.
To get over your problem you will have to sand back the edges around the walls,ceiling & skirting boards..Then cut in again but make sure you thin that part of the paint down then roll the walls again making sure your as close to the edges as possible..Do one wall at a time only.
These users thanked the author dubman2 for the post:
vlb
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Post by wine~o »
agreed "picture framing"
I use a different technique to dubman2..
I cut in then drag the brush and paint down the wall (from ceilings) to feather in to the rollered line.
vlb
ian gibson
Has thanked: 100 times
Been thanked: 122 times
Post by ian gibson »
One way to stop picture framing is to cut in, say a metre at a time, and then roll over it with a lightly loaded mini roller as tight to the ceiling/skirting/frame as possible. This way you replicate the texture of the main rolled areas thus eliminating brush marks/framing.
These users thanked the author ian gibson for the post:
vlb
dynamod
Elephant Man
Has thanked: 592 times
Been thanked: 1444 times
Post by dynamod »
Some brands and colours are more prone than others. Some Dulux deep base colours were bad for this.
Nihil expectore in omnibus
ian gibson
Yes, reds especially can be problematic, also sometimes with darker colours if your roller is damp before you start it will cause shading to happen, best dry your roller thoroughly before starting.
dynamod
Elephant Man
Post by dynamod »
I use Armstead Trade on the charity shop projects mixed to a dark blue RAL5002, a screaming pink RAL4010 and a green RAL6033.
They are the most lurid colours you ever saw, and in Armstead, they don't frame or misbehave at all. Armstead emulsion is very good if you're not looking to spend a fortune and want a paint that just works.
Leave that retail gash in B&Q if that's what you've been using. :thumbright:
These users thanked the author dynamod for the post:
vlb
dubman2
Post by dubman2 »
some Reds can be very poor covering sometimes..Dulux came out with a colour called Crushed Berry.it's a nice colour but was difficult to use..I painted a customers dining room in it & it took 5 coats to get a good finish.
I'm a big fan of Armstead trade as well.I use it on nearly all my ceilings & there eggshell for bathrooms.
dubman2
Post by dubman2 »
No thanks or anything from the original poster..He's getting free advice from professional decorators & he can't even say thanks.
vlb
Post by vlb »
dubman2 wrote:No thanks or anything from the original poster..He's getting free advice from professional decorators & he can't even say thanks.
apologies, i have just come back to this after unexpected some time away.
If you look at all my previous questions i ALWAYS express my gratitude at the advice i receive.
These users thanked the author vlb for the post:
Desmondo15
vlb
Post by vlb »
dynamod wrote:I use Armstead Trade on the charity shop projects mixed to a dark blue RAL5002, a screaming pink RAL4010 and a green RAL6033.
Yeah it usually is B&Q lol
