Hello,
I'm trying to install a Nest Thermostat 3rd edition to a new Baxi 428 combi boiler. I have fitted the Heat Link to the wall and put in trunking, but an not sure on the wiring looking at both manuals. I am not sure if I should be following the instructions in the Nest manual for 230v combi boiler or Low voltage/dry contact combi boiler?
This was a brand new central heating install, so no existing thermostat.
From Nest installation manual
From Baxi Boiler installation manual
How my boiler is wired right now
Any help would be very appreciated.
Wiring Nest Thermostat to a Baxi 428 Combi Boiler
- Has thanked: 893 times
- Been thanked: 729 times
Re: Wiring Nest Thermostat to a Baxi 428 Combi Boiler
X8 OT on boiler, remove the link, connect two wires to it & OT1/OT2 on Heatlink.
The 3rd generation is supposed to operate on Open Therm.
Open Therm is a two way digital control, with the 0s & 1s jumping back & forward.
240v switching is an On/Off Control only. OT is a ‘Master & Slave’ communication, which can modulate the boiler easier.
HTH
HTH
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
The Plumbers Anthem
Gas Safe RGI
- Has thanked: 1 time
Wired up as you said and it's working perfectDickie wrote:X8 OT on boiler, remove the link, connect two wires to it & OT1/OT2 on Heatlink.
HTH
Thank you!
Thanks for your expression of gratitude. A wee donation to the charity in my signature would be appreciated. I hope you were like me & enjoyed a wonderful healthy & happy childhood.buntonn wrote:Wired up as you said and it's working perfectDickie wrote:X8 OT on boiler, remove the link, connect two wires to it & OT1/OT2 on Heatlink.
HTH
Thank you!
Unfortunately, some kids don’t. Thanks.
The Plumbers Anthem
Gas Safe RGI
The Plumbers Anthem
Gas Safe RGI
