tile adhesive not set 3 days later
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
What a pain in the @ss!
i have tiled up a window reveal and I noticed that the tile adhesive has not set yet. I haven't grouted it in yet so I can see adhesive is soft like putty. Will it harden up over time? Some tiles I can still push down into the adhesive.
I just noticed the adhesive is out of date (just bought it last week from builders depot). Do I have any option here except strip them all off and redo?
- IMG_20171201_114450.jpg (301.7 KiB) Viewed 10115 times
- IMG_20171201_114446.jpg (309.95 KiB) Viewed 10115 times
- Has thanked: 807 times
- Been thanked: 3496 times
Re: tile adhesive not set 3 days later
It is usually the other way around I have found in that older adhesive goes off too quick. It is probably due to moisture in the wall and it is just acting slow to set. The only air that gets in is through the grout lines and the comb tracks in the adhesive. Give it a bit longer and see how it goes. Also, as an experiment, put some adhesive on a tile and leave it to set and see how long that takes.
- Has thanked: 1300 times
- Been thanked: 1175 times
What was the temperature?
Here for instance (Don't know if it's the right specific instructions)
https://www.google.co.uk/url?sa=t&rct=j ... B_Dyimlq3A
It says not to use blow +5 degrees C.
Possible a window reveal could be cooler than that.
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
What size of tiles are they? If they are large format tiles then the adhesive won’t go off.
- Mr. Grumpy
Thanks for the response,
Dave, house is warm, easily 15+ i'd say
Steve, only 250 x 200mm (7mm thick wall tiles)
after I posted I lifted off the tiles on the bottom part of the reveal, they came off easily by hand (didn't even need a scraped under there. The adhesive is soft and a touch crumbly. I have cleaned them off and let the tiles dry out, cleaned up the ledge and reapplied BAL (1:1)
the side walls seem sort of ok so I'll not poke about with them, they don't get any movement or interference, so I'll leave them and see how it goes. Maybe they might harden up over the week.
DWD good idea about putting adhesive on the tiles. I'll not grout for a few days and see what happens
- Mr. Grumpy
Actually come to think of it? That date on the tub, would that be the manufacturing date ?
Edit: ok looking at Reviews on screwfix, its seems like others are having the same problem.
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
Never used that product and nearly always use a dry addy. However I had one earlier this year using 100mm sq tiles for a small basin splashback; wasn't worth buying a 20Kilo bag, so used this
https://www.screwfix.com/p/mapei-waterp ... -5kg/64982
worked for me
worked for me
- Mr. Grumpy
Was curious by your suggestion DWD so tried it. left it a room at 20deg heat for more that a day and a half. Adhesive comes straight off and is crumbly and soft. Seems like they made a bad batchdewaltdisney wrote:Also, as an experiment, put some adhesive on a tile and leave it to set and see how long that takes.
- IMG_20171202_190500.jpg (409.08 KiB) Viewed 9985 times
Ahh, that explains it. Just as well you know for certain and the experiment proves it. Fire off a letter to Mapei. They may well send you a voucher which is not great help to you I guess. But they may want the rest of the tub for test and production tracking and it might help others in the long run.
just found this thread, I might try this experiment.
I have 2 large tubs of adhesive, about 2 years old, never been opened.
I will open one and see how it looks then try it.
Dave
Dave
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 566 times
JagoGeep, Bad form digging up such an old thread. I've locked it.
