Isolation Valves for a toilet
plumbing, drainage and waste water questions here please
Ryles
Has thanked: 13 times
Post by Ryles »
Hi
I was about to buy a standard isolation valve to replace a seized one in my main toilet but the bloke in B&Q told me I couldn't use compression valves on the type of pipe I have (although they seem identical to the one currently fitted). The type he suggested wasn't in stock so I'm confused at to what i'm looking for.
Can anybody point in the right direction please (see pic attached)?
I've seen this advertized on Screwfix but not 100% sure...
STRAIGHT SERVICE VALVE 15MM X ½ "MM
At the top there is a plastic screw attached to a metal valve and then going into a pvc pipe.
thanks
darrenba
Has thanked: 104 times
Been thanked: 490 times
Re: Isolation Valves for a toilet
Post by darrenba »
These users thanked the author darrenba for the post:
Ryles
gas4you
Has thanked: 419 times
Been thanked: 894 times
Post by gas4you »
:withstupid:
Make sure you get the fibre washer with it
These users thanked the author gas4you for the post:
Ryles
Dave
Return to “Plumbing Forum”
