laptop running hot (CPU?)
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Post by wine~o »
Basically as per title. Fan is clear of dust and has been blasted with canned air. CPU runs at mid to high 60's C under very low load*, fan on full speed and can be heard running... even when closed (the forum pages) the fan at full speed and CPU running hot ... Intermittent though. some days fine and then other days just seems to want to run hot ?
Ideas???
* just a couple of forum pages open
boxedin
Has thanked: 61 times
Been thanked: 319 times
Re: laptop running hot (CPU?)
Post by boxedin »
Hi Wineo
When you say low load what programmes are loading at start up check in windows 7 its system configuration/ startup and services and you can disable from there to get the full picture
What programmes are automatically checking for updates constantly eg Chrome every 15min adobe if you turn them off what if anything happens
What AV program are you running have you tried disabling my problem was mainly AVG
Does it run hot on start up ? what is the rpm of the fan running at (download speedfan to check)
boxedin
Post by boxedin »
speccy is good for hardware overview with temperatures download the free version of course
https://www.ccleaner.com/speccy
These users thanked the author boxedin for the post (total 2):
gas4youwine~o
Rating: 14.29%
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Post by DIY_Johnny »
i would check to see what processes are running in the background, do a malware and antivirus check.
Another possibility could be that the CPU heatsink has come loose. They can do over time . Happened to mine!
These users thanked the author DIY_Johnny for the post:
wine~o
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Thermal compound between heat sink and processor can also 'dry out' and require replacement.
These users thanked the author kellys_eye for the post:
wine~o
DIY_Johnny
Mr. Grumpy
I would add that fans which come with PC's are pretty bog standard. You get buy a much better one that run near silent.
I have a liquid cooler external fan set up, ....but I'm a nerd.
It keeps the CPU at 35deg even at overclocking and running benchmarks. Before I changed it, the heatsink came loose and temps ran to 90 deg and it would just shut down.
wine~o
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Post by BillyGoat »
DIY_Johnny wrote:I would add that fans which come with PC's are pretty bog standard. You get buy a much better one that run near silent.
Bit awkward for carrying around a laptop after doing that mod to it.... :mrgreen:
kellys_eye wrote:Thermal compound between heat sink and processor can also 'dry out' and require replacement.
:withstupid:
wine~o
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
Yes, it'd happened to this desktop machine after about 18 months. Checked the temp and it was still up after dusting out.
These users thanked the author Dave54 for the post:
wine~o
wine~o
Post by wine~o »
boxedin wrote:speccy is good for hardware overview with temperatures download the free version of course
already had speccy installed hence knowing the CPU was running too hot.
Looks like I will have to remake the heatsink. Bugger of a job on the laptop though.
:withstupid:
Lappy got worse... when switched on this morning went up to 70 degrees just running speccy
Currently using the old laptop that you saved for me Billy Goat. :salute:
boxedin
Post by boxedin »
Hello wine~o
Is it running windows 10? have you upgraded to windows 10 if so it might possibly be another potential cause to rule out before disassembling
https://fossbytes.com/windows-10-cpu-te ... eat-issue/
DIY_Johnny
Mr. Grumpy
Just a thought, has the fan connector come loose by any chance?
wine~o
Post by wine~o »
DIY_Johnny wrote:Just a thought, has the fan connector come loose by any chance?
:dunno: I'll take it apart and have a look. Oh and if it is a pcb fault what oven temperature and for how long ?????? :shock: :?
DIY_Johnny
Mr. Grumpy
shove the whole lot it, what possible harm can it do :mrgreen:
boxedin
Post by boxedin »
If you put the whole lot in as solder melts at 188c (gas mark 5), then the plastic would melt before the solder and it would come out like a plastic blob with some bits of metal in wouldn't it ?
https://www.ifixit.com/Guide/Temporaril ... +oven/2240
DIY_Johnny
Mr. Grumpy
boxedin wrote:If you put the whole lot in as solder melts at 188c (gas mark 5), then the plastic would melt before the solder and it would come out like a plastic blob with some bits of metal in wouldn't it ?
Yeah i think he knows I was joking, ...... or I hope so !
Return to “Computers”
