Help on monitor mod
macadac
Has thanked: 2 times
Help on monitor mod
Post by macadac »
hi im new here and need a little help. I have this monitor lying around and wish to hook my dvr to the monitor but this monitor is from a car no video output that fits into dvr
How would i mod this to make it fit my dvr to receive my cctv image here is a pic of dvr and monitor Image
Sent from my SM-G930F using Tapatalk
macadac
Re: Help on monitor mod
Post by macadac »
DVR
macadac wrote:hi im new here and need a little help. I have this monitor lying around and wish to hook my dvr to the monitor but this monitor is from a car no video output that fits into dvr
DVR
Has thanked: 47 times
Been thanked: 2590 times
It sounds a good idea, but unless you can connect the input of your monitor directly to the DVR output it will not work, you may also need some additional hardware.
If it doesn't work as I first said, you will probably spend more time trying to do it than you would if you got a new monitor (I use el-cheapo TV's for my CCTV, the latest ones have multiple input sockets. just plug and play)
macadac
Rossl1985
Been thanked: 5 times
Post by Rossl1985 »
i would that the monitor/tv is missing some parts, normally if they have no inputs built into the unit then there is a separate metal control unit which is designed to be hidden away under the dash board of a car etc which has all the inputs on it.
is there a brand or model number on the tv its self at all? is there a reason your not using the pc monitor you already to view the CCTV? i mean most new flat panel monitors will support VGA and DVI meaning you could use it for both CCTV and PC although you would not be able to view both inputs at once.
macadac
Post by macadac »
Rossl1985 wrote:i would that the monitor/tv is missing some parts, normally if they have no inputs built into the unit then there is a separate metal control unit which is designed to be hidden away under the dash board of a car etc which has all the inputs on it.
This monitor was in a car as sun visor monitor. reason i wanted this monitor i was thinking mount to wall and it be on constant. so i can see cctv all the time
Why not do as I suggested? buy an el-cheapo TV and mount it on the wall. This one came from Tesco
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
The red/black pair are the power connection.
The other white/black pair are the video input (it may be that the white is video, the black is audio (or vice versa) and that your 'common' should reference to the supply negative wire). Whatever, you can't do any harm by mis-wiring them anyway......
Get a video lead that fits the 'video out' socket on your DVR and connect the two together.
Your problems may start with the differences in video signal standards i.e. is the signal from your DVD the same 'type' as that from the original feed to the display?
macadac, is there a "back" for the monitor you have?
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
whats the make and model of the screen ? it should be marked on the pcb
the input could be anything composite, gvif or even proprietary
imho its not worth messing with, you can pic up a 15-17" vga lcd monitor for peanuts or even free from the likes of Freegle or Facebook
ebay example,
https://www.ebay.co.uk/sch/i.html?_from ... or&_sop=15
These users thanked the author Bob225 for the post:
macadac
macadac
Post by macadac »
someone-else wrote:macadac, is there a "back" for the monitor you have?
yeah there is a back piece
Return to “Computers”
