well yesterday when i pulled the plasterboard down insulate the garage ceiling i found this hidden away under the plasterboard
i could never work out why there was no power to the light fitted at the back of the garage, now waiting on a junction box to fix this mess
nice surprise in garage ceiling
- Has thanked: 814 times
- Been thanked: 3508 times
Re: nice surprise in garage ceiling
Makes you wonder where else Bert Bodger has applied his expertise
- Has thanked: 2 times
- Been thanked: 5 times
it does but i have found some very strange things while ive been doing the house so far.dewaltdisney wrote:Makes you wonder where else Bert Bodger has applied his expertise
fair bit of bad/strange plumbing, door linings been held in with 300mm + screws and no end of cut cables, joist and stud walls that have strange centres, light switches that were located closer to the ceiling than the floor (people that lived here before must have been tall thats all i can say)
pretty much every room i have done so far has ended up with having to put right someone else half a** bodge job before i can get done what i set out to do
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2571 times
Just as a point of note. You are not supposed to use junction boxes in places that will not be accessible. You should use wago connectors or similar (And wago box) as they are maintenance free.
It also looks like there is no earth?
- AlwaysLearning (Sat Oct 12, 2019 12:23 pm)
the junction box wont be in the ceiling mate as only the lighting ring is in the ceiling and the three core + earth is lower than ceiling height so the junction box will just get mounted to the plasterboardsomeone-else wrote:Just as a point of note. You are not supposed to use junction boxes in places that will not be accessible. You should use wago connectors or similar (And wago box) as they are maintenance free.
there is an earth mate but just they never put green and yellow sleeve over it, another job half done badly
