Joining 2 metal rods for strength
- Has thanked: 1 time
Hi all,
I have a chair whose tubular leg has snapped (please see photo) - it was a clean snap as I think there was an existing join during manufacture. I want to repair it but do not have the equipment or ability to weld it so was planning to insert a rod inside the two bits of tubes and use an epoxy resin to glue them in place. Due to the curvature of the tubes, I do not think I would get more than 20mm into each tube (if that) and was planning to use a mild steel rod. Do you think this will be strong enough to take the weight of a person? As you can see from the photos, the forces acting upon it will not be directly downwards.
Would a wooden rod also do the trick as it'll be a lot easier to cut this to length.
Darius
Darius
- IMG_0282.jpg (744.55 KiB) Viewed 4107 times
- IMG_0283.jpg (536.2 KiB) Viewed 4107 times
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2342 times
Re: Joining 2 metal rods for strength
doomed to failure in my opinion
may work if its properly welded
if you insert a rod its surface area will probably be less than 60% off the tube surface area so need to be twice as rigid to have any chance off working![Dunno :dunno:](./images/smilies/smily1386.gif)
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2591 times
I think it will be a case of try what you can do, and see what happens.
To get a precise answer will require more information such as what materials have you, what are the exact dimensions of everything, what tools do you have etc etc, hence my first comment, try it and see.
Inept people use the QUOTE BUTTON instead of the QUICK REPLY section![Smile :-)](./images/smilies/icon_smile.gif)
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
![idea1 :idea1:](./images/smilies/idea1.gif)
- Has thanked: 201 times
- Been thanked: 513 times
If you are using a steel rod it should be possible to heat it up to bend it to the curve of the tubes. That way it'll go much farther into them. Then use a resin to take up any space and hold the whole thing rigid.
- Has thanked: 1300 times
- Been thanked: 1175 times
It looks to me as if it's a mild steel inner tube, with a thin outer of stainless or similar.
I've seen that before somewhere.
It looks as if the inner has been butt welded originally from the heat marks seen inside.
If you do decide to try the epoxy route, and nobody can say for sure what if anything will work, then make sure everything, inside the tube, and the insert rod, is thoroughly roughed up with coarse abrasive to "key" it, and degreased with alcohol or similar.
- Has thanked: 250 times
- Been thanked: 212 times
Wooden dowel (broom handle cut down) hammered in nice and tight might work.
- Has thanked: 825 times
- Been thanked: 3574 times
I repaired a broken mower handle in a similar way. I had found some steel tube that was a perfect fit and I pop riveted it in place to secure the join. It worked fine but the carburettor then started playing up so I junked it as I had ran out of patience.
The only thing I would say is that your broken leg will take a lot of pressure from downward forces and an insert will need to be pretty tight fit and a fair length to spread the load. I suspect it will join my mower at the recycling centre.
Wish I had a fiver for every time I've done something similar.dewaltdisney wrote:I repaired a broken mower handle in a similar way. I had found some steel tube that was a perfect fit and I pop riveted it in place to secure the join. It worked fine but the carburettor then started playing up so I junked it as I had ran out of patience.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Despite my earlier post, I reckon you're right. If it was me, I might have a look around for another seat base that'd suit if the chair itself was something I liked.dewaltdisney wrote: The only thing I would say is that your broken leg will take a lot of pressure from downward forces and an insert will need to be pretty tight fit and a fair length to spread the load. I suspect it will join my mower at the recycling centre.
