Hello all,
Just thought I'd introduce myself - I'm a newbie from Harrow/NW London - been living in newbuild apartments the last 10 years but am now in the process of buying a detached 1967 house in Pinner (pic attached), and it needs updating and we'd also like to knock through a couple of walls.
I've never done this before but am keen to attempt to get the work done within 10-12 weeks by way of getting individual trades involved rather than handing the job to a design-build type place.
Standard stuff we'd like to do:
1. Strip the interior
2. Knock through a couple of walls, block up a couple of doorways (building regs permitting)
3. New Flat Roofs and Guttering
4. New windows
5. Remove wallpaper and skim/replaster where needed
6. Get new power points chased in, incl wiring for spotlights
7. New plumbing/heating/boiler
8. new kitchens and bathrooms
7. Paint whole house
8. Move in
I've probably got the sequence wrong and i'm prob being naive about doing all of this first time with no experience. Wish me luck and expect several questions!
Thanks!
Newbie embarking on a first time renovation!
- Has thanked: 105 times
- Been thanked: 878 times
Re: Newbie embarking on a first time renovation!
Welcome to the forum
Only thing I would add to that is if your doing all this work and it hasn't been done already, get the place rewired and a new CU, I take it you will not be living there while the work is going on ?
Thanks for the welcome messages.
Re the Consumer Unit - I'm in two minds - the current one was fitted in 2011 and the wiring - i'm told by the surveyor - is in good condition and that building regs for wires haven't changed materially since the house was built in 1967... so to replace or not to replace I wonder...?
