**Help** Immersion heater timer wiring!
trialanderror
Post by trialanderror »
Hi All,
I'm new to here and i would be so appreciated if you all can give me your professional advice on this.
I'm looking to replace my broken immersion heater timer with a new one. I took my old one apart and can see there're 6 holes. A hole for the ground wire, netural, L, 1, 2 & 3
However, for the new one i that bought there're only 5 holes. Could you all please take a look whether my wiring diagram for the new one is correct or not ? Number (1) on the left is from the main switch into the timer and (2) is from the immersion heater.
I've also included few more photos of my water cylinder and the set up of the switches.
Many thanks,
Chester
Hot water cylinder, switches and timer
Water cylinder.JPG (121.32 KiB) Viewed 3219 times
Power set up
Power set up
Main switch, boost and timer.JPG (111.71 KiB) Viewed 3219 times
Old immersion heater timer closeup
old immersion timer.JPG (147.85 KiB) Viewed 3219 times
New immersion heater wiring diagram
pic 2.jpeg (113.29 KiB) Viewed 3219 times
Old immersion heater timer wiring
pic 1.JPG (133.35 KiB) Viewed 3219 times
ericmark
Has thanked: 117 times
Been thanked: 783 times
Re: **Help** Immersion heater timer wiring!
Post by ericmark »
It would seem it is set up for off peak electric use, often called Economy 7. In the old days the bottom immersion heater was active at night and should give you enough hot water to see you through the day, however if it failed then the top immersion heater could be switched on, but it only heated top half, often used a timer that would just heat water for an hour. The white meter did bottom and black did top.
However as time went on people wanted to use off peak for washing machines etc. So new systems were used, where the switching was often done by the home owners timer rather than the DNO's timer.
Image Special timers are normally used. Some allow two supplies, and some just one, Image and since where I live near everyone has gas, I can't tell you which are which, I just know they exist.
So question one is do you have off peak electric? Many have found off peak does not suit their life style so have got rid of it, so may be you no longer have it and the two immersion heaters are from the past.
However before trying to explain how to connect we really need to know.
Has thanked: 47 times
Been thanked: 2575 times
Since you already have a timer and are just replacing it, I don't see the point of asking what supply you have.
Your diagram is correct.
OnlyMe
trialanderror
Thank you so much both! I really appreciate for your reply.
Return to “Electric Forum UK”
