Printing Problems
Posted: Wed May 02, 2018 11:17 am
by johnM20
I have an Epson SX210 printer running from Windows 7. This has worked fine until very recently when for most (but not all), documents it will only print part of it and then stop, usually ejecting the page. Does anyone have any suggestions as to the cause and, even better, what the cure is.
Many thanks in advance.
Re: Printing Problems
Posted: Wed May 02, 2018 3:37 pm
by Beav
johnM20 wrote:I have an Epson SX210 printer running from Windows 7. This has worked fine until very recently when for most (but not all), documents it will only print part of it and then stop, usually ejecting the page. Does anyone have any suggestions as to the cause and, even better, what the cure is.
On the maintenance settings on the printer (if it has a screen?) try some of those such as clean print head, nozzle check etc. It may be the actual print head then it works out cheaper to just buy a new printer.
How long have you had that one if you don't mind me asking?
Posted: Wed May 02, 2018 3:58 pm
by johnM20
Thanks for your reply. I've hooked the printer up to my laptop as a test and it prints perfectly so is something to do with my PC that is stopping the print mid stream. It isn't anything to do with 'Maintenance'.
Posted: Wed May 02, 2018 4:28 pm
by wine~o
Try re-installing the software for the printer, mine came on a CD, :dunno: how yours came packaged.
Posted: Wed May 02, 2018 5:51 pm
by johnM20
Tried reinstalling disc, made no difference. Thanks anyway
Posted: Wed May 02, 2018 7:15 pm
by Bob225
tested with the same usb cable on both machines ? tried different usb port ?
Posted: Fri May 11, 2018 11:23 am
by PatBS
Can you run a test print from Windows? The test print should print out one of those funny sheets with all weird symbols/marks on. Maybe try cleaning your registry?
