Tiling on damaged plasterboard
Hi, I intended to tile on plastetboard in the bathroom. I've had to remove some awful plastic cladding which had been put on with glue. Even being really careful ripping this off is damaging the plasterboard (see pictures). Just some advice really: do I go ahead and tile over the damage, replace the plasterboard or plaster over it before tiling? I'm replacing the plasterboard around the bath and wet areas with aquaboard anyway but this is on a 'dry' wall.
- damage to plasterboard, glue has pulled off board paper
- 20180508_092401.jpg (324.1 KiB) Viewed 3026 times
