Removal of gripper rods
parkgate
Has thanked: 60 times
Been thanked: 6 times
Post by parkgate »
I have removed the carpet and underlay from my stairs with a view to fitting a runner stair carpet and the painting the edges of the stairs, not covered by the carpet, white.
Removing the old gripper rods I am using a screwdriver and hammer to lever out the tacks holding the gripper rids in.This leaves a small gouge mark in the staircase which isn’t ideal!
Is there a way to remove the rods without damage?
Thank You.
Rorschach
Has thanked: 119 times
Been thanked: 1043 times
Re: Removal of gripper rods
Post by Rorschach »
Several methods, putty knife and pry bar usually works well. You can also dig at the tacks on top of the gripper rod so any damage is limited to the rod itself.
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
A old 1" chisel does the job for me with minimal marks
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Post by wine~o »
Slide a stripping knife under the gripper rods before prising off with a screwdriver/chisel whatever. Sometimes the gripper rod breaks and you'll need a pair of pliers to remove the tacks.
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
I bought a couple of cheap chisels for rough work and they do the job without a lot of effort
https://www.toolstation.com/shop/Hand+T ... sel/p40558
Mike
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
parkgate wrote:Removing the old gripper rods I am using a screwdriver and hammer to lever out the tacks holding the gripper rids in.This leaves a small gouge mark in the staircase which isn’t ideal!
Not with a screwdriver ... follow the suggestions above and pick the thinnest tools, e.g. scraper. Then you can use a bar like so http://www.olympia-tools.co.uk/products ... ility-bar/ there are some which are pretty thin on the ends. It is the width and (thinness) of the bar that will stop damage to the wood.
PS. I am not saying that the bar above is the thinnest there is (I have two different makes but not that one).
EDIT. Here is another example that I got somewhere https://www.ffx.co.uk/tools/product/Est ... y-Bar-15In probably too late anyway.
parkgate
Post by parkgate »
I used a wallpaper scraper with excellent results.
The problem I have now is to repair the gouge marks made when I used the screwdriver!
Thank you for your suggestions!
OchAye
Post by OchAye »
As you will be painting the wood white, a 2 part wood or car body filler would do.
If you decide you might want to keep the original look of the wood it is a bit more complicated. There are fillers in colour but you must judge the colour after you varnish a test area as the wood will darken with the varnish/oil or whatever you use. There are also fillers that will take stain and others that will not.
