Tiling curved shower
Posted: Mon Apr 21, 2008 10:58 pm
by allintheprep
Hi
My client wants me to re-tile a curved shower using mosiac tile on a back sheet. However rather than tile on top of exisiting tiles they want me to remove these first. Therefore I'll be working back to the original backgroud. Now my questions are:
1) If the background needs to be re-plastered or alike, whats the best way of doing it and using what.
Am I right in thinking you can get shower kits for this? But does this allow you to re-create the smooth curve if the removed tiles create a bumpy surface?
All help appreciated.
Ta
James
Posted: Tue Apr 22, 2008 6:12 am
by ultimatehandyman
This could be a difficult job and so I hope you have lots of patience.
Many tilers will agree that if you use mosaic tiles in a shower area then it is essential that you tank the area first using a tanking kit, hopefully it will of been tanked previously.
I'd be careful when removing the tiles so that patching up is left to a minimum. If you need to patch use multi finish plaster and then leave it until it is completely dry and then tank over the whole area with a tanking kit.
Posted: Wed Apr 23, 2008 10:50 pm
by allintheprep
Thanks for that. Tapping the existing tiles it sounds like some solid wall and plasterboard. Going by the other tiles in the room they were stuck solid and obliterated the plasterboard underneath.
Any top tips for removing tiles?
The sheets of mosiac are a natural stone tile with approx 5cm sq tiles. I'll be off to my local friendly tile flair to check out the tanking kit.
I'll keep you posted with progress.
Posted: Thu Apr 24, 2008 5:50 am
by ultimatehandyman
Removing mosaics will be difficult and time consuming I would imagine.
Normally I just get a tool behind the tiles and thn lever them from the wall, such a screwdriver. You could try a wide scraper if you can get one that is sturdy enough.
Posted: Fri Apr 25, 2008 6:47 am
by allintheprep
Ta for that. Luckily they are standard tiles. I'm putting up the mosiacs. Fingers crossed the existing come off when i start monday.
Posted: Fri Apr 25, 2008 7:30 am
by handyman
I would always think the worst, then it can only be better. I would also guess if its tanked, it will be knackered if you take the tiles off
give us a picture once you have them off
